Drilling Straight/Plumb Holes ....
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: Drilling Straight/Plumb Holes ....
    Posted: 26 Apr 2020 at 6:15pm
in concrete?? I had to mount 4 "plates" of steel with 4 holes/plate onto a concrete slab to install sleeve anchors. I thought I did a decent job of "sighting" the angle of attack, but after driving the anchors in, what a mess Confused. Is there an efficient way to keep the hammer drill "true" ?? Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 6:43pm
i always set the anchor bolts in the wet cement when poured with a piece of plywood to hold the bolt straight. i've never had to drill any holes in concrete yet.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 7:00pm
A person used to be able to get an attachment for the front of the drill that kept the drill plumb while sliding forward to drill the hole.  I don't know if they are still available but you could try google.  I don't know what you would search for though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 7:25pm
Seems like years ago Black and Decker had a drill that had a bubble level incorporated into the handle ??
GARY(OH/IN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GARY(OH/IN) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 8:58pm
I used to have a good eye for keeping the drill on a 90 degree angle with the floor. These days I can't even drill straight in a pine board.
FloydKS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FloydKS Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 9:04pm
I have not tried it but I have one of those little levels that hangs on a string... maybe mounted to the top of the drill???
Grayray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Grayray Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 9:04pm
Try using a block of wood like a piece of 2x4 or maybe a little thicker.  Drill the size hole you need in the 2x4 at drill press to be sure the hole is square and true to the board.  Then set this board on the concrete you want to drill and use it as a guide to keep the drill straight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pat the Plumber CIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 9:07pm
I use the longest bit I can and hold an older bubble level against the side of the bit . Usually if you can start them plumb they stay plumb , until the bit hits the side of a hard rock and send it off caddy wampus
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 10:10pm
My older drill has an attachment to keep it square. I got it at our
Local Ace hardware store years ago. Hope you can find 1.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 10:37pm
You're probably doing alright the way you are, the problem is (as Pat the Plumber) says, when you hit a rock in the concrete, it sends the bit wherever it wants to go.  NOTHING can do you any good.  I laid mud for years and if you don't put them in when you pour, it's a pain.
The way I do it is to drill ONE hole, insert the anchor and bolt it in place.  Now, using the plate as a guide, drill the second hole and insert anchor and bolt that one in place.  Now move to number 3 and then 4 doing the same thing.  It's the only way I know and the only one that I've ever seen work.  Good luck!
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 10:44pm
Ted has it....
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 6:28am
And here I thought I was the only who does that
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 7:18am
yeah TedJ is right agin.... !!!
as for ...
just HOW can you SEE the bubble after you pull the trigger ??? espeically with a hammer drill !!!LOL
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 10:41am
X3 on Ted's method. Have installed many many at work that way. I hesitate to throw out a number but know on some of the guard rails we have put in took over 50 3/4" anchors. You get tired of drilling holes at that rate.
This page was generated in 0.107 seconds.
