Looking for d10 grill shell |
D10rebuild
Topic: Looking for d10 grill shellPosted: 20 Apr 2020 at 6:59pm |
Looking for a grill for my d10. Ot was my grandads tractor and I think he used more like a dozer than a tractor so I’m trying to find a good grill shell. Thanks
Tracy Martin TN
Joined: 11 Sep 2009 Location: Gallatin,TN Points: 10937 |
Posted: 20 Apr 2020 at 8:40pm |
Not to steal your thread,I don't have a grill shell, but I do have reproduction grill guards like the original AC ones. HTH Tracy
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5191 |
Posted: 21 Apr 2020 at 7:23am |
Try Paul Barnsley (Paul B on here). He's not too far from you in Maryland.
PaulB
Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5279 |
Posted: 21 Apr 2020 at 5:08pm |
The only thing I have here is from the D10 industrial with a Henry loader, it has the bottom cut out for the pump drive. So nothing for a restoration. D10/12 sheet metal is tough to find. I've been searching for a D10/12 gas tank that's bent up, rusted out or shot at. I can't even find crappy sheet metal.
Larry in NC
Posted: 21 Apr 2020 at 6:11pm |
This is a little off topic, but I have over the years parted out several D10's. Sheet
metal is the first to go. Folks need fenders, hoods and grill shells, gas tanks. I stopped parting anything out, first because it is a lot of work and I am getting older, and second parts don't sell nearly as fast as they once did. You can't buy a D10 or D12 to part out cheap, so you have an initial investment to recover before you can make anything on the tractor. An individual can not come close to getting the prices that the salvage yards like Wenger's get. In regard to your grill shell search. The shells (radiator surrounds) for all three series are the same except the series III shells do not have holes for headlights. Grill shells from all Series can with used with minor modification depending of the Series tractor you are installing it on.
Edited by Larry in NC - 22 Apr 2020 at 11:11am |
D10rebuild
Posted: 21 Apr 2020 at 9:14pm |
Ok thanks guys, I’m sure somthing will pop up eventually.
Jeeper38
Posted: 22 Apr 2020 at 6:18am |
When I was fixing up my D12 I got a complete trans and a set of cylinders from a guy in Minnesota. I'll send you a PM with his info.
PaulB
Posted: 22 Apr 2020 at 10:54am |
The series III radiator surround is different from the earlier ones. The early ones DO have the headlight hole and DON'T have the holes for the front weight. Also the grill screens were different.
D10rebuild
Posted: 22 Apr 2020 at 1:24pm |
What shape is that industrial grill you have, my brother is very good bodyman so i do beleive he could fill the hole for the pump.
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55299 |
Posted: 22 Apr 2020 at 6:23pm |
If you can get a D-15 series 2 grille , you may have enough material, to make a D-10/12(series 3) grille out of it. I think I read somewhere, that someone sells the series 2(3) grille metal, but can't recall where.
Edited by DiyDave - 22 Apr 2020 at 6:25pm |
