Industrial d15!!!
Jk chalmers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Topic: Industrial d15!!!
    Posted: 16 Mar 2020 at 8:34pm
Going on a road trip tomorrow to Northern Ohio to get a low hr original rubber With a post driver on the front that carrol county owned for putting fences up.... is it tomorrow yet??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2020 at 8:34pm
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2020 at 9:38pm
Sweet!  Interesting exhaust.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2020 at 10:01pm
He said the air intake is that circle thing and the exhaust is like a orchard exhaust says it looks factory..??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2020 at 10:02pm
Who the heck knows till I get there tomorrow lol
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2020 at 10:47am
that popped up on Facebook, i thought about buying it, I drive through Collins when i go to Work. $1900, not a bad deal.
dan
Edited by Acdiesel - 17 Mar 2020 at 10:48am
D19 diesel,D17 diesel SER.3 D14 NF,D14 WF, D15 SER.II wf
D15 SER.2 DIESEL,D15 ser.II nf
D12 SER.I, D10 Ser.II
2-720'S
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2020 at 1:50pm
It’s in working order Except the three point Raises sticks in the up position besides that everything works as it should pretty happy! But need advice on three point...
HagerAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HagerAC Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2020 at 3:25pm
Seeing this prompted a question. A couple weeks ago i stumbled on what appears to be a mysterious d15. It was yellow but looked pretty much like an ag version d15 series 1. I didn't examine it very close but i saw it in a farmers shed when i was there.   It had ag wheels and a power director so it kind of threw me off. It also had some kind of loader on it. Im thinking it's just a normal d15 that might have gotten painted yellow, but could have it been offered this way as an industrial? It's been sitting and is not in very good shape but its had my mind wondering what it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2020 at 3:44pm
I would say if the hand clutch is on the left side it is industrial and it’s a forward and reverse not high and low.. buy it!! lol
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2020 at 4:34pm
for now just going to change oil spark plugs clean it up grease it up and free three point adjustments.. and hydro oils
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2020 at 7:34pm
Advice for the 3pt: Take it OFF and store it away, install a Snap-Coupler.  If that poorly designed 3pt is used, at best it will fall out from under the tractor. At worst it will strip the threads out of the housing.
 If the traction-booster lever is set too high the arms will raise and not come down. This can also happen if the link to the pump is incorrectly adjusted.
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2020 at 6:53am
That's an I- 60 or I-600 which is the industrial version of a D-15 Series II
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2020 at 9:05am
Industrial 615 is the model. I’m in love with the fact that I don’t have to shift to go in reverse I just pull the hand clutch backwards what a great idea
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2020 at 10:16am
Remember the pto speed if you want to put a brush cutter on it, different speed on the shuttle shift units IIRC . . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2020 at 10:49am
Yeah after I get the 3 point working any advice on what the Recommendations on brush hogging and using a 5 foot tiller on it is the only two things I do... thank you!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2020 at 10:57am
Sorry that probably made no sense what would the PTO brush hogging RPMs be on this machine for tilling or brush hogging? Or where can I get a manual better yet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2020 at 1:40pm
https://www.allischalmers.com/forum/i600-pto_topic132683.html
Prior discussion on one I was looking at bringing home from 2 miles down the road.
I passed, bought another D15II AG version for running cutters; heat build/reliability on 540 rated cutter even with big gear box was not something I wanted to try.
Not to say it won't work, just not for me  . . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2020 at 1:55pm
I got this photo about 15 years ago... dont know who he is... nice tractor !!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2020 at 4:03pm
Thanks! And yeah beautiful tractor!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2020 at 7:03am
Any D-14/15 or the industrial version I-60,I-600, 615 with a shuttle will have a PTO speed of approx 780 rpm and be equipped with a PTO shaft with 21 splines the same as the standard small 1000 rpm shaft. This is because of the extra gears needed to speed up and reverse the low side of the power director clutch in order to make it a shuttle. The PTO is driven from gears ahead of the Power director/shuttle clutch pack.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2020 at 11:09am
The 615 pictured was a highway dept. mower which we purchased and restored.Judging from the positive responses here, I should find another one.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 19 Mar 2020 at 12:58pm
Yeah I got it just to flip it and I don’t think it’s going anywhere for quite some time lol
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2020 at 6:24am
The first D15 industrials were nothing but an ag tractor with a HD non adjustable wide front and standard color was yellow. In 1961 Delaware county Ohio ordered several industrial D15 tractors with optional adjustable wide front ends from Larcom and Mitchell in Delaware. Think about that one for a minute. They ended up with yellow painted farm tractors. Why can I remember all of this when I was only 6 at the tine? Because Delaware County didnt take all of the order and stuck L&M with a couple. Dad had one brought to the farm for a demo and I remeber well it being yellow. After a week on the farm he told them to take it back and paint it orange and when it was delivered he would have a check for them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2020 at 6:55am
Nice story! Hopefully you have a picture or two? I have a cat skid steer so I suppose that’s one of the reason I like this color as well haha. I love the gas pedal option as well!
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 20 Mar 2020 at 9:18am
Interesting input on all having small 1000 pto shaft as I have crawled around two over the years and both had standard 540 shaft . . . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2020 at 11:06am
I have an  I-600 with a shuttle and the small 1000 PTO shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2020 at 11:18am
Let’s see more pictures of these industrials!!!
Ken stanwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken stanwood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 4:29pm
If I can figure out how to get images to load I would show you mine. It's bit of work in progress. And when I say progress, I mean really slow progress. It has a broken spool valve right now and that pretty much has me dead in the water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jk chalmers Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 5:04pm
I need to take a updated picture of how much better it looks now after going through it and getting everything to work and fixing the hydraulic post driver leaks!!
Dave(inMA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave(inMA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Apr 2020 at 5:18pm
jk, please do take some pictures and post 'em for us all!
Fun stories about those yellow D15's!
WC, CA, D14, WD45
This page was generated in 0.297 seconds.
