7010 slippage. Power director or torque limiter |
Page 12> |
Albertan7030 ![]() Bronze Level ![]() Joined: 02 Apr 2014 Location: Alberta Points: 7 |
![]() ![]() ![]() ![]() ![]() Posted: 21 May 2020 at 10:54pm |
Thanks for the reply. That is a pile of info. I did the brake test and the steering went dead as if I shut the tractor off. I agree some slip is better than a tranny rebuild but at 210 hp I should be able to drive around my yard without slippage! I am prepared to do the limiter as the tractor is 45 years old just wondering as mentioned before what a guy should do for sure as well as parts to get while it is split. Is that intermediate plate recommended like a pressure plate in a normal clutch set up or is it machinable like a flywheel if it is worn?
tbran ![]() Orange Level ![]() Joined: 14 Sep 2009 Location: Paris Tn Points: 3539 |
The spring centered torque limiter is the shock absorber of the power train. The spring center absorbs the pulses of power as does the weight of the flywheel. This helps prevent wear on the teeth of the clutch discs on the PD or PS tranny as well as the splined coupler at the rear of the trans that powers the high low rear gears that powers the pinion. The torque limiter must be allowed to slip for max transmission life. The original torque limiters were thought to be adequate because the testing was done by good operators and engineers ( keep in mind, if something fails in test - it has to be fixed - and the bean counters don't like that. Also some things are cheapened up BY bean counters - most have to restored to original design ) When the 7030's and 7050's went to the field then the 7040 60's and they wound up close to 20,000# then the complaint of sluggish low hp came and the pumps were sent of and turned "10%" to get the customer off the service reps back, the torque limiters started failing. The fix was to increase the thickness of the back plate, the belville washer, taller spools to allow for the thicker part and finally a shield to keep leaky trans and rear main seals from lubing the pads of the limiter. The flywheel, if machined properly and if the proper parts were installed would hold 200 hp in all applications for thousands of hours. IF you double spring it - it will not slip. IF you have a good operator who understands how to start a load it will never slip anyway - but we all boo boo and "pop" the clutch by accident or panic at times and that is when the torque limiter does its job by slipping a few revolutions allowing the engine to lug down and slowly start turning the gears avoiding a harsh, damaging clutch engagement. Changing a torque limiter every few thousand hours is a lot less $$$ than a PS or PD or other failure. Another way to check the slippage of the TL is to rev the engine to about 1800, turn on the PTO, hold the brakes and let out on the clutch fairly quickly to make the unit slip and have someone observe the PTO speed - if the pto never slows it is the PD/PS clutches, if it stops and the engine continues to run , it is the TL slipping... be careful using this test as if the engine TL is not at fault and the engine lugs down - it can lower the speed of the pumps and allow the clutch to slip - which allows the engine to rev thus bringing the pump volume up which makes the clutch grab and the cycle will continue never killing the engine. Finally on a power director the high range clutch has no belville washer buffers thus requiring less pressure to engage. If we have a PD slipping in low range we push the button or switch to high range and see if it pulls in high - this will be a rather violent shift if the low range is slipping. One can also hold the high range floor button down and let out the clutch for a wheelly popping experience...
I’ve got a 7080 doing the same thing. I called about parts and the parts lady said the disc and spring are most common to wear. She said there is another plate to the assembly but it shouldn’t wear bad. Should a guy be doing the whole power director while he’s got it split or just seals? My power director valve needs seals for sure. The disc from AGCO is 4 pad which I have read is better because of surface area/ pressure? I don’t mean to steal a thread just trying to learn and help others that might need the same info. Thanks.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8651 |
BTDT
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1939 |
Isn't a that what they are designed for to slip and protect the transmission? you would lose that by doubling up the washer. Unless you are tractor pulling and are making a bunch of horsepower and not up and down shifting all day long like a farm tractor. Those tractors are in the 40 year old range get a little oil leak and they slip. Fix the limiter and seals and be good for another 40 years.
Some used two Belleview washers and shimmed stands. MACk
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8363 |
Good luck with it,, a new assembly should last for years
bleeds orange ![]() Orange Level ![]() ![]() Joined: 11 Sep 2012 Location: mt. vision, ny Points: 692 |
Probably best place to get these parts would be agco dealer?
Double it" as in use one belleville spring not 2?
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
My uncle and my cousin have been full time farming with 7000 and 8000 series tractors since the mid 1980's and never has one had a torque limiter problem. I've been running a 7050 and 7030 for over 20 years and though I'm not a full time farmer, I've never had a torque limiter go out..... knock on wood
Wink I am a Russian Bot |
Despite neg post about torque limiters they are not a problem as a whole. If you have oil seals start leaking that oil will eventually get in the limiter and cause slipping. Not the limiters fault. Lots of hours and depending on type of use,the hub can break out...a wear item. When things are right they are not a problem. Part of the burnishing procedure when installing new is to center limiter on flywheel so the driven shaft doesn't eat up the splines on the other end being off center.
"Double it" as in use one belleville spring not 2?
Double it and you will take splines out of the PD or something else.
While it is split, reseal PD. and rear main seal. MACK |
Im really not to familar with the 7000 series torque limiter ; but have followed all posts on them - is there anything different you can do to elimenate the torque limiter ? Seems they are quite a problem in these tractors
A-70269732 Allis-Chalmers End Plate Clutch TRACTOR: 4W220 7010 7020 7030 7040 7045 7050 7060 7080 7580 8010 8030 8050 8070 Our Price: $137.39 |
Yes obviously flywheel forgot.
I tried looking up the pressure plat on agco books got the part number but when I google a new the oem part numbers dont match. 23 spline 12" with 4 pads or with 6 pads? It's not a 20 spline correct? |
machine flywheel for sure and new pressure plate
Get new clutc disk ,belleville washer check rear main seal and what else?
Thanks cory |
torque limiter
2300 rpm in field with plows up I stand on brakes to bring tractor to a halt and power steering does not work.
Not yet. Getting moldboards ready today
So have you stepped on the brakes to stop forward travel yet? What did you find out?Hydraulics work or not?
I'm not that experienced....just been reading here for years. Doc,MACK,Lynn,Tbran....those guys have the experience
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22049 |
Check the oil level on the dipstick under the seat with the tractor sitting on the level and after sitting overnite. Check BOTH SIDES of the dipstick. By your own description you just wrote.... " It just acts like someone pushed the clutch pedal in as I'm discing". So, did the power steering still work while this episode occurred ?????? The correct answer to that question is key to a proper diagnosis.
Edited by DrAllis - 21 Mar 2020 at 9:14pm |
The engine rpms seem to stay the same maybe go higher a little . It just acts like someone pushed the clutch pedal in as I'm disking. If that helps
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
I have a feeling that the engine won't stall because something is slipping to cause your original issue?? Does the engine rev up during your "slippage? Sadly, I might be one of those that need a drawing, but I "think" this one I may be on the right track with the engine dying?? Those are sharp looking tractors BTW,hope you can resolve the issue :-)
If everyone was so experienced in orange equipment as SteveM is then maybe the forum wouldn't exist.
Thanks for help doc and mack. Yeah a little more detail does help. I just assumed if I was full throttle in tractor and stood on the brakes it would stall and of course nothing would work because tractor died. Thanks cory |
Page 12> |
