looking for a 816 hydraulic pump |
david a ![]() Bronze Level ![]() ![]() Joined: 29 Jan 2012 Location: almond Points: 67 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Mar 2020 at 8:19pm |
Looking for parts or the whole hydraulic pump for back hoe also the steering pumpand valving. Mine are getting tired
Eric B ![]() Orange Level ![]() ![]() Joined: 09 Feb 2012 Location: British Columbi Points: 900 |
It may not be that easy to find a good used pump but it is a Commercial Shearing pump which is good news if you shop for a new one. If you find the numbers on it you can search availability online. It's two stage, the main stage puts out 25 GPM and the smaller 15 GPM. If you come across any Case 680 E's or G's they may have the same main hyd. pump I don't have any details on the power steering pump.
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41329 |
What is happening with the pump - are the wear plates on sides of gears worn to allow bypass or other problems ?
You might be able to rebuild your pump . Had a pump on a NH 785 skid loader that went bad -new from NH was a arm and leg price but found a Cessna pump new that matched - except input shaft was keyway rather than splined - switched input shafts (worked straight across) new pump / old shaft - 1/4 the price |
haven't taken it apart yet. It is getting weak and slow would thing the end plates are starting to were. Was going to see if I can put them on the surface grinder at work
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8079 |
You wouldn't want to grind on wear plates. they are soft metal,sometimes bronze
I know when I saw my 816 pump taken apart the surfaces looked like sand or gravel had gone through the pump and yet I was told that's what general wear looks like after lots of hours on the machine. If the rest of your machine is in pretty good shape it should be worthy of a brand new pump, you'll probably get one for maybe around $1000. You may possibly find a used one but if it's simply a "take off" it's only a guess what shape it would be in as well. A new 40 GPM pump really makes that machine move and lots of power to boot. My 816 would pick up the front end of my gravel truck off the ground using the front cutting edge held flat, that's 11000 lbs.
thanks will pull it apart when the weather gets better Like the idea of replacing it with a cessna pump. The tractor Is tired,has a newer motor trans and rearend when do you put it out of it's misury
