One wire alternator wiring diagram |
| Author | ||
1947WC
Joined: 11 Dec 2015 Location: Wisconsin Points: 214 |
Topic: One wire alternator wiring diagramPosted: 14 Feb 2020 at 1:02pm |
Show me a one wire alternator wiring diagram
| Sponsored Links | ||
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 24767 |
Posted: 14 Feb 2020 at 1:44pm |
One wire goes from alternator stud to battery +ve. Yeah, it's that simple. All the 'smarts' are in the alternator.
1947WC
Posted: 14 Feb 2020 at 2:47pm |
Thank you JBMiller
Posted: 14 Feb 2020 at 3:24pm |
I always try to help if I can... A problem with 'one wire' alternators is their startup RPMs. You can get them to run better with a smaller pulley. Steve @B&B will KNOW what the RPM should be as I've yet to see any 'datasheet's on them at 'selling ' sites. They'll list volts, amps, sizes but not the important stuff !
lowell66dart
Joined: 10 Jul 2013 Location: Paulina La. Points: 964 |
Posted: 14 Feb 2020 at 4:55pm |
You can buy a self exciting alternator, no need to rev the engine.
This is the way I've wired a few. Get a nice tinned terminal strip. Marine places have them. Blue Sea makes a nice one with a cover for less than $20. Run your wire from the one wire alternator to the terminal strip. Now run a wire from the terminal strip to the positive lug on your starter. Your battery is now being charged. The terminal strip can now be used to power anything else that need 12 volts. Very simple. Not correct for any type of restoration but for a working tractor safer than a bunch of brittle wire.
C in Concord
Joined: 26 Sep 2019 Location: Concord, WI Points: 109 |
Posted: 14 Feb 2020 at 8:48pm |
I found this diagram helpful when I converted my C to 12v with a one wire alternator.
Leave things better than you found them.
1941 Model C (restored 2020) |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12017 |
Posted: 14 Feb 2020 at 10:48pm |
Yikes! Using that diagram above is asking for trouble fir' sure with an Alternator doing the charging chores. Using an Ammeter AND the 3 postiion switch is looking for a fire or a BBQ on board! There's a handful of ways to wire your Tractor, but the above diagram is not the safe way. Get one wire to short, or the Ammeter to fail, and you got shish-ka-bob for wiring, and possibly loosing the Tractor and in a matter of seconds! All I can suggest with this setup is to keep a fire extinguisher close by the drivers area. To each his own....
Posted: 15 Feb 2020 at 5:57am |
Gee Steve it's not that bad overall unless I'm missing something.... The fuse at the alternator protects it and 'stuff' after.... The fuse in the light switch will blow if lights or wiring short out. However there should be a 'main' fuse at #(5), feed from battery to ammeter. That protects everything in case ammeter fails or anything 'downstream'. If the decades old fibre step washers mounting the ammeter are replaced with nice, new nylon ones, it virtually eliminates 'ammeter meltdown' and draining the battery with leakage from ammeter post to ground. Just curious as to what you see that my eyes don't.
C in Concord
Posted: 15 Feb 2020 at 8:51am |
No fire, BBQ, or shish-ka-bob since converting... Sounds like you're h-angry Steve . I'm just trying to help the guy out. If you really think that diagram does more harm than good, please be constructive and post your "safe way" diagram.
Thank you for the constructive notes JayB. I'm going to take a look at adding that fuse and checking the washers on the ammeter (a voltmeter is in my future). System's been working well for nearly a year now, but there's always room for improvement, especially when it comes to safety. |
Posted: 15 Feb 2020 at 9:13am |
The problem I see with ammeters is lack of maintenance. 50 years ago they were installed with cheap 'fibre' ( aka paper) insulating washers. Over time ,they breakdown due to heat, water, heck 'old age'..... and allow a constant trickle of current to flow from the power studs to ground. This small current flow is why after a month or two of storage , 'grr..%$%(*^& battery's dead again' . I remove the ammeter, clean up the studs, paint the U-shaped retaining strap and use nylon stepped washers. I also place a flat washer between every lug and one under the nut. This keeps the wires from turning when you tighten the nut( old Bell telephone trick). You also need to look at them once in awhile ! Spiders and wasps can get in and make nests, and the 'trickle' of current flows again....**&&^ battery's dead, arrgh !
MikeinLcoMo
Joined: 12 Sep 2009 Location: west plains mo Points: 620 |
Posted: 15 Feb 2020 at 9:19am |
What amp fuses are we looking at?
39B 42B 48C SFW 52Cub Cub Cadet 70 S14 Speedex M14 Speedex S18 Speedex
C in Concord
Posted: 16 Feb 2020 at 9:59am |
Depends... I've read the old ammeters were rated for 30 amps, so that is the limit for the diagram above. If your wiring gauge and length can support 30 amps, (link to table), you should be able to put a 30 amp fuse between the alternator and ammeter. If you have lights, each light circuit fuse should be set based on the draw, light wattage / voltage, x quantity of lights. Again, with sufficient wiring gauge and length to support. As an example, my system is ~5ft. of 10ga. wire with a 30 amp fuse between the alternator and original ammeter. I have three 27watt LED flood lights on ~5ft. of 16ga. protected by a 7.5 amp fuse ((27watts/12volts) x 3 lamps= 6.75amps). I'm sure I've over simplified for our electrical experts, but it works. |
Steve in NJ
Posted: 16 Feb 2020 at 11:37am |
H-angry? What does that mean? Thought I explained in my post. You don't need another diagram. Loose the Ammeter, and the three position switch. Install a Voltmeter and a good 15-20 amp Headlight switch, and there's a great start to making it safer. Just trying to help. Wasn't my intent to offend anyone...... Steve@B&B
Brian Jasper co. Ia
Joined: 11 Sep 2009 Location: Prairie City Ia Points: 10508 |
Posted: 16 Feb 2020 at 12:05pm |
C in Concord
Posted: 16 Feb 2020 at 12:22pm |
No worries Steve. It's a play on the food/cooking metaphors you used in your last post. Meant to be light-hearted. Thank you for reconstructing the diagram with the voltmeter and headlight switch suggestions on this post. |
Alberta Phil
Joined: 13 Sep 2009 Location: Alberta, Canada Points: 3937 |
Posted: 16 Feb 2020 at 3:12pm |
H-angry. Never seen that word before!! Describes me if I don't get fed on a regular basis! Just ask my daughter or ex-wife!!LOL
AaronSEIA
Joined: 11 Sep 2009 Location: Mt Pleasant, IA Points: 2573 |
Posted: 16 Feb 2020 at 5:08pm |
Snickers used it in their TV advertising a few years ago. Made for funny commercials. AaronSEIA
Steve in NJ
Posted: 17 Feb 2020 at 6:40am |
Ben, thanks for esssplaining that. Never heard of that before either. LOL! I guess when you get older, you don't pay much attention to the new metaphors. Being married to an Italian wife who is kick a$$ in the kitchen, I don't miss to many meals...
![]() Steve@B&B
Posted: 17 Feb 2020 at 6:57am |
gotta be homemade pasta , homemade sauce lucky man ! |
Steve in NJ
Posted: 17 Feb 2020 at 7:05am |
You nailed it Jay! I should be 300 lbs by now!! If it wasn't for me being constantly on the roll, I probably would be tippin' the scales pretty high, but I'm a little half of that weight and trying to stay there. Its tough though... LOL!
Posted: 17 Feb 2020 at 7:40am |
Look at it this way, who BETTER than you to ENJOY homemade pasta and sauce !!! Course NOW I'm hungry...too bad I don't have my passport...sniff,sniff. Jay
chaskaduo
Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
Posted: 17 Feb 2020 at 7:58am |
Wow a buck fifty, you must not get wet coming in from the car in the rain.
