Educate me on the B
Parris001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Topic: Educate me on the B
    Posted: 04 Feb 2020 at 3:01pm
I recently inherited my Papaw McDaniel’s Allis Chalmers model B tractor. From the time I was old enough to climb up on it I’ve played with it. Papaw unfortunately passed when I was young so I never got to help him on the farm and using the tractor.
The B has always been a runner. There’s never been a time when it fell into disrepair and wasn’t operational.
I can’t decide whether to restore it or just get it mechanically solid and leave the patina.
I want to know more about it as far as what year model it is. It has the small gas tank for gasoline but my uncle said they’ve never ran kerosene in it. Always just been a gas tractor.
Someone please point me to a good source for researching these so I can know what it is I’ve got here.
Edited by Parris001 - 05 Feb 2020 at 6:38am
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 3:23pm
Welcome!
Here is an interesting read that covers the history, development and changes to the B (and related C and CA) over the years.
I'm sure someone will be along shortly, (Gerald, I'm looking at you) to give a link to the manual.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 3:44pm
Originally posted by HoughMade HoughMade wrote:
Welcome!
Thanks so much for the rapid reply
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 4:16pm
The serial number is by the shift lever on the transmission.. Should say B xxxxxx . Tell us what the number is.  Also give a picture of each side and we can tell you a lot about your tractor...
Does it have a battery box under the gas tank ?
Does it have foot brakes on the back, or two hand levers by the fenders ?
Does it have a hydraulic pump at the back right side of the axle ?
Does it have a generator on the left front corner of the motor ?
The small gas tank is a plus......... probably not a lot of them left around after 70 years.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 4:19pm
 Tried to post a pic. I’ll look it over well and get these questions answered.
Thanks!
Edited by Parris001 - 04 Feb 2020 at 4:21pm
Post Options Post Options   Thanks (1) Thanks(1)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 5:54pm
Welcome to the site.  Some good books on the subject, By Norm swinford, and C.H. Wendell.Wink
Post Options Post Options   Thanks (1) Thanks(1)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 7:04pm
Parris001,
Welcome! The B is a nice tractor, and being a family tractor, anythings you do to keep it operational will be a good thing!
mdm1 View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 7:16pm
As others have said welcome. This forum has been a great help to me. Always keep a family heirloom if you can. As far as restoring or just keeping it in it's working clothes is entirely up to you. Your tractor do as you please. After you find the serial number go to tractordata.com and you will find some basic info. Oh ya send some pics. If you can't post them email them to me and I would be happy to post them for you! Good Luck.
Gerald J. View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 9:06pm
I have a shop manual on line at:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
And a military WW2 manual in that same directory:
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2020 at 6:06am
This time of year I leave the house in the dark and return in the dark. So I won’t get to see my new little tractor again in the daylight until this weekend gets here. I did go out in the dark and the rain this morning though and try to get the serial number. I found the casting pad where it says “Tractor No” but I couldn’t make out the number that was stamped. I’ll have to bring sand paper next time.
The battery box is not under the gas tank. It’s under the steering column right behind the electrical box. It does have brake foot pedals and not hand brakes. I’m not sure about the hydraulic pump, but it does have a generator on the left corner of the motor. Which, doesn’t gen so I’ve got to get it off and take it to Todd’s here in Nashville.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2020 at 6:34am
To help read the tractor number, shine a flashlight at a low angle. You may need to do that at several places but eventually you see the numbers.
You can also use a dental pick or similar to remove paint from inside the 'numbers'.
A QUICK pass with a wire brush may help....
there may be other 'tricks'.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2020 at 6:43am
Battery, Generator, Foot brakes........... all GOOD info !
1939Dodge View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1939Dodge Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2020 at 6:53am
unless it’s a rust pile, clean it up and wax it. Patina is a badge of honor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2020 at 7:13am
I thought about cleaning it up and leaving the patina put laying a fresh set of decals on it. Kind of a contrast of the old and the new.
I was also thinking about taking advantage of the novelty of making it run on kerosene. But it looks like maybe that took its own unique intake manifold? I realize it makes significantly less horsepower on kerosene (I had a buddy in high school that had a Rambler he ran on kerosene) but thought it might make the tractor a little more interesting. There’s no fuel line attached to the bottom of my little gas tank so it appears this was never used on this piece of equipment.
Edited by Parris001 - 05 Feb 2020 at 8:07am
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2020 at 8:39am
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2020 at 10:32am
IF you have or could ever find the kero. parts needed, you could convert it just for novelty sake. Does it have starter or hand crank?
I have 3 B's here. 38, 40, and 48.  Interesting little tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2020 at 12:26pm
It has a starter and I have the hand crank as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2020 at 12:36pm
Keep the little tank just for show... Run the tractor on gasoline for good performance.If your paint is half way decent, I like the new decals and polish the old paint !
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Feb 2020 at 4:08pm
Can't go wrong with a Little B. Mines been in the family since my grandfather bought it new in 48. First tractor he had on the farm
Ranse View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 9:04pm
Welcome to the forum. It's good to see another middle Tennessee guy. I have a B as well, fun little tractors. Unless you just want to paint or it looks real bad, I'd say leave it be. Allis folks seem to appreciate them either way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 2:27pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 2:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 2:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 2:30pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 2:31pm
So I finally got to see her good in the daylight. The serial number is B57153 so it's a 1942 if I'm reading it right. Started the tractor up and putted around the yard with it.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 3:01pm
that's right, an early 1942
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 3:20pm
what ever you do, SAVE that muffler.......... got to be a classic !
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 4:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Parris001 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 5:36pm
Really?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 8:39pm
NO........... just a bad joke !
This page was generated in 0.138 seconds.
