76 gleaner k cracking kernels |
bleeds orange ![]() Orange Level ![]() ![]() Joined: 11 Sep 2012 Location: mt. vision, ny Points: 692 |
![]() ![]() ![]() ![]() ![]() Posted: 07 Nov 2019 at 6:34am |
Recently purchased this machine sives,concaves and rasp bars are like new. Cylinder slowed all the way down,I raised cylinder clearance up to 3/4". Still cracking kernels.
Help please. Thanks cory |
old farmer ![]() Silver Level Access ![]() ![]() Joined: 12 Oct 2011 Location: Sturgis, Mich Points: 341 |
How many concave bars are you using and how wet is the corn?
25%. Not sure on how many concave bars
What size pulley are you using on right side of cylinder? How much corn is in return? Are you settling cylinder clearance by gauges on side, or measure? MACK
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22074 |
Correct cylinder pulley for corn is 20 inches in diameter and almost rubs on the tailings return tube. Cylinder speed needs to be 500 RPM or less. How fast are you running it ??
Setting cylinder clearance by gauges. Nothing in the tailings return. Cylinder speed is slowed all the way down. I will check pulley. Bin is free of debris, just cracking kernels is only problem
Thanks cory |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8658 |
Unless you have "set" your gauges, I would not trust them
So back to the concave ?. If I have 5 or 6 than removing some will help my cracking situation? How many concave s is acceptable?
Thanks cory |
Three for corn. One on the door....skip.....concave....skip...….concave.
Edited by DrAllis - 07 Nov 2019 at 11:55am |
I have only 3 conclaves. So I'm in search of a 20" drive shieve.
It has an 8.5" shieve on it now. Thanks cory |
Just paint "Jimmy" on it and call it a day! Sorry, couldn't help myself!!
I never run one on door in corn unless I'm in rocks or dozed ground with roots. Corn will beat door latch to death.
If you have the 8.5 pulley, you grinding corn. I think I have a 20" pulley, will check tomorrow. MACK |
you should be able to shell all the corn off 25% cobs with 3 concaves...get below 18 and get by with 2
Ok thanks MACK. Let me know on that pulley.
Thanks to everyone else. |
Pete from IL ![]() Silver Level ![]() Joined: 29 Dec 2009 Location: Beecher IL. Points: 311 |
You will need a longer belt also with the bigger pulley.
JimIA ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Castalia Iowa Points: 1983 |
We ran a K in corn for about 15 years. Great little machine for the job. I played with it gradually and finally got it dialed in where I liked it. Had a good set of bars, 20" pulley and three of the round concave bars in the places they recommended above. If the corn is wet or has the cob mold you will need to add a standard concave in place of a round concave bar. Your not going to completely eliminate cracking in todays yields but this setup always worked very well for me.
No 20" pulley, only a 16.5. MACK
All the F-2's were sold got the 16.5 inch pulley. The slowest it would allow was 500 RPM, which is still plenty fast for corn, but when doing beans you didn't have to change to another size pulley.
FREEDGUY ![]() Orange Level Access ![]() ![]() Joined: 15 Apr 2017 Location: South West Mich Points: 5396 |
OMG Mack, that makes PERFECT sense about the corn/door rasp bar!! May I ask what position of the bars you run in corn ? We have aftermarket wide spaced cylinder bars in the F2 now. Thanks .
Start at second position then 4 for two bars. Book tells you how to space. Every other one. If more are needed for complete threshing they add at the rear on concave door. I don't have rocks so I run 2 concaves in #2  in corn and beans.
Like SteveM said, but always one on door in beans. There's always a stick or something around the edges. MACK
JimWenigOH ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: NC Ohio Points: 1198 |
For this very reason, I had picked up a 16.5" at the salvage yard some time ago and was going to put it on my K2 to harvest beans this fall since the decal on my combine listed this combination as an option. I found out there was no belt made for putting the 16.5" on the K2, so went back to the 13".
soybreedingboy77 ![]() Bronze Level ![]() Joined: 14 Dec 2011 Location: Illinois Points: 185 |
Should be the same belt as the F2
BLEEDS ORANGE, what was your solution to the cracking?
I usually pick around 18%. this year it was 21-22. I cracked a bunch of corn. Wonder if that's part of the trouble?
No more cracking of the kernels. Made sure I had 3 concave bars, which I did. I had to buy a 20" drive pulley for cylinder, and a longer belt of course.
Machine does a nice clean job. Thanks cory |
MACK, I hope your right on the rasp bar placement (none on the door in corn). I removed the door bar and installed bars at #2 and #4 spots. The original setup was door and #3. Dad swore it had always had 3 bars in it
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8367 |
Leave it in the field, itll dry down
Doug, I'm all for it but dad is working himself into a coranary because all of the BTO'S around him are done
Alot of the ruts will freeze out during winter. I hope. MACK
