It beats cranking by hand
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Topic: It beats cranking by hand
    Posted: 28 Oct 2019 at 8:23am
About 40 years ago, I mounted an old washing machine motor to Dad's JD#1A corn sheller. He used it to hull black walnuts.
 I got help to haul it out of the old barn so I could put it back to use. When I get done shelling about 10 bushel of corn that sat in this wagon of 3 years, I may run some walnuts thru it.[TUBE]TF9VoCph1n0[/TUBE]
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2019 at 8:26am
I need a belt for the chaff fan, maybe an old singer sewing machine could donate the material for one.
 Some day, I may even route the chord away from the flywheel and put a switch on it.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2019 at 9:29am
They still carry those little round leather belts for sewing machines, and you can adjust the length if you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2019 at 1:02pm
Some day, I may even route the chord away from the flywheel and put a switch on it..
NA... wait for OSHA.. Im sure they would give you DIRECTIONS !!
Brian F(IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian F(IL) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2019 at 4:11pm
I'm probably gonna regret this, but I gotta ask...
What are you doing with the corn cobs?
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2019 at 4:53pm
Charlie, how is the pulley mounted on the inside of the big wheel on the sheller.  Or is it a factory deal.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2019 at 6:23pm
[QUOTE=Brian F(IL)] I'm probably gonna regret this, but I gotta ask...
[/QUOTE
used in the out house!
I am still confident of this;
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2019 at 6:25pm
Charlie I've seen guys use cloths line, or similar, just wrap it around, tie a good square knot. seems to work for lite loads like running a fan
Wait for the Lord;
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2019 at 6:29pm
Phew, for a minnit there, judging by the title, It beats cranking by hand, I thought the thread was goin in an entirely different direction!WinkWink It beats cranking by handIt beats cranking by hand
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2019 at 6:41pm
Never heard IT called "cranking".
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 29 Oct 2019 at 9:03am
The cobs went on a big ash stump and got burned. If I had a couple hundred bushel to shell, I might have enough to burn the stump down half way.
 Dave, I'll have to look, but I think there is a flat belt pulley on the inside of the flywheel. If the belt is tight enough to get it rolling, it works just fine.
 I googled a new leather belt, and a replacement for the John Deere lists for 12-25 $
You can buy the same belting in a 72 inch length for a sewing machine for $2 to $6 and cut it to length.
 I got about 4 bushel dumped in the basement yesterday, filled the stove up last night and the fire was out this morning when I woke up.
 First snow, and coldest it''s been since last spring, and my feed auger isn't feeding. Now I have to vacuum out the hopper and check for a jam, then probably open the back of the stove up to see if the set screw on the motor shaft came loose.
