Allis Chalmers B water pump
GPNX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GPNX Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers B water pump
    Posted: 22 Sep 2019 at 4:27pm
I am new to the forum.  I recently purchased an allis chalmers b tractor that needs work.  The water pump was leaking so i ordered a new one.  I have also purchased manuals on this tractor for servicing an maintenance.  I have been through books i got all all over the internet and for the life of me can't find torque spec for reinstalling water pump.  Does anyone know what it is.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 4:46pm
Welcome to a great forum. I just put one on a B and just tightened it up. I'm sure someone will know if there is a torque spec. Post some pics of your tractor. Where in WI are you?
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 4:56pm
You can look up the torque spec for your bolt size on the internet, you also need to know the SAE grade also. Probably grade 5.
Ranse View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 5:02pm
I put one on my B. I didn't realize there was a torque spec. I did just did as mdm1 did, just tighten it. It works and don't leak, I figure it's good to go.
GPNX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GPNX Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 5:08pm
I am in st croix falls wisconsin. thanks for the feed back.  for the people that installed the pump did you use rtv sealant like on a vehicle for the gasket?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ranse Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 5:22pm
I used no sealant at all. Just the gasket that came with the pump. I thought about using something, but I haven't had a problem yet.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 5:26pm
I think the manual says shellac. Yep just looked.
Edited by chaskaduo - 22 Sep 2019 at 5:28pm
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 8:01pm
I used just the gasket as well. No problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 8:46pm
nobody had a torque wrench in 1940 ... Most mechanics are just familiar with "tight" for a given size bolt.. If your not as experienced, then I would use a grade 5 torque for that size bolt and call it good.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 9:46pm
Page B-C-15 in the shop manual I have says "tighten securely" for the water pump mounting bolts.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
BEK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BEK Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2019 at 5:51am
Use anti-seize on the bolt threads just in case you or somebody else ever needs to work on it again.
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Sep 2019 at 6:48am
If you need parts I have several of these tractors apart and on the shelf. Just parted another last week. Located in Elk River MN. lselkriver@gmail.com
