agco allis 9435 transmission problem.
teffgrass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote teffgrass Quote  Post ReplyReply Direct Link To This Post Topic: agco allis 9435 transmission problem.
    Posted: 30 Jul 2019 at 11:34pm
I bought this tractor and the 4 speed power shift doesn't shift. And the pto doesn't turn on. I'm thinking about replacing all the sensors on the transmission. It's been sitting for a few yrs so there is a bit of corrosion.
Any help would be great. Thank
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2019 at 9:20am
If I remember right these tractors had a lot of electrical gremlins.
Wink
I am a Russian Bot
Fogarty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fogarty Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2019 at 3:57pm
My brother in law had a 9775. ( iirc)
That thing was a transmission electrical nightmare.
They had multiple dealers look at it, they called Agco at the time.
No such luck.
It did that until the day they got rid of it.
caledonian View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote caledonian Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2019 at 4:14pm
You may have a cracked sensor that is leaking oil.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 31 Jul 2019 at 8:46pm
You should have a code in your monitor. Not a good ground has been the biggest electrical problem I have saw.       MACK
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 10:15am
If that tractor has a 32 speed trans its a Massey transmission.   First, talk to a experienced Massey mechanic and confirm that is does. Second, check to see if your tractor has the second generation computer installed.   When the computer fails it does what yours is doing. The computer controls the power shift, pto, fwd, and diff lock. The first generation computer was faulty. They all need to be updated. I know, because I have a Massey of that year and had to do mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teffgrass Quote  Post ReplyReply Direct Link To This Post Posted: 01 Aug 2019 at 5:52pm
Thanks very much for the reply. I'm going to repair all the transmission sensors to start with.
Post Options Post Options   Thanks (0) Thanks(0)   Quote teffgrass Quote  Post ReplyReply Direct Link To This Post Posted: 17 Sep 2019 at 8:51pm
this tractor has a 4 speed power shift with the 4 speed range shifter.
I'm trying to figure out the sensors and wires on the side of the trany
It includes wire numbers 15,16,33,and 34 can someone tell me how it's supposed to be wired.
