"b" weights work on "CA"?
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: "b" weights work on "CA"?
    Posted: 19 Jul 2019 at 12:29am
I have a couple front side weights from my dad's 1950 Allis Chalmers b. Can I use these on a 1953 Allis Chalmers CA?
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 6:46am
I think you will have to rig up an adaptor to make them fit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 2:05pm
Yes, takes a longer bolt for the front that threads into the bolster and I made a few bushings also that "ride" inside the front hole and cover the bolt shank.
Have em' in the shop somewhere but you just need to heft one of the ol' gals up to align the rear hole after measuring how deep the front hole is. Front bolt length is correct when the rears line up exactly as the front bolt hex head nestles inside the weight hole.
May take a few attempts to get it lined up exactly on the rear hole by adjusting the front bolt so have a cold beer standing by for when you finish as those weights are darned heavy.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 3:42pm
Anybody know what they weigh?
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 3:50pm
90 pounds each
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 5:58pm
I got a set of front wishbone weights, for a B, If you wanna go that route...Wink
DSpears N IL View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSpears N IL Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2019 at 7:24pm
I had a pair of b weights mounted on my CA until I found a pair of the correct CA weights about 20 years ago.
