RARE FORKLIFT NEED HELP AU-1420 |
SFV_818
Topic: RARE FORKLIFT NEED HELP AU-1420Posted: 10 Jul 2019 at 12:41am |
Hi, I bought a uleaded gas 4750 lbs lift tht I beleive from online research is a 1971. It has one plate on the outside chasis /that says TYPE G 173A AU-1402 It sounds good when running but is blowing blue smoke it can be many things like head gasket oni need to know engine and searchable part refernces like engne type etc it also needs brakes the front has no serail number plate I am uploading the reference plate I have the engine is stamped 4512 F I would lso like to try and get a manual I internet searched the au-1402 and two things came up one this was taken over from lstansteel corp in 1971 (Collection 1402) to allis collection 54 and that some of these models have sold at auction refeenced au-1402 about 3 Thats all I know, can anyone help me shed some light on this model including engine type or what to look for / similiar models for part etc? Any help is apreciated, Jeff
Jim.ME
Posted: 10 Jul 2019 at 5:16am |
Several photos of the machine and engine might help. If your photos are large (high pixels), resize to about 680 x 500 with paint or other program for best viewing here.
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25296 |
Posted: 10 Jul 2019 at 5:26am |
as Jim says , pictures are worth MORE than 1000 words... either resize on your 'device' to 640 x 480 aka VGA or 'email' size or 'upload' them into your spot in the 'file manager' here.We're give 80 megs of free storage,so over 200 'VGA sized' pictures. Once saved, you can resize then add them to your post. Jay
SFV_818
Posted: 11 Jul 2019 at 11:50pm |
Hi, thank you both for your replies.
I took a few pictures and can see an engine stamp of 1-3-4-2 then 2-5-4 also another part of the engine is stamped HUS I am attachg the pictures resized as suggested. I
am gettng a lot of blue smoke like I mentioned and was told by seller
he thought a thicker oil is needed, Im not sure but can use help on
identification of this engine and hopefully a way to order a manual I can hardly stop s brakes will be my first order of operations hopefully. I hope some of these pictures means something to some one it seems the 1-3-4-2 relates to engine firing ![]() ![]() ![]() ![]() ![]()
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 55328 |
Posted: 12 Jul 2019 at 4:50am |
I believe HUS is Hussco, a valve supplier. THere should be a data tag, somewhere on the lift, similar to the last picture, with model, s#, and load capacity, etc...
Calvin Schmidt
Joined: 11 Sep 2009 Location: Ontario Can. Points: 4583 |
Posted: 12 Jul 2019 at 5:28am |
Looking at a few clues and the size of the forklift leads me to think you have a 153 Buda engine. Pictures of the engine don't tell me much. Not sure about the angled oil filter.
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1128 |
Posted: 12 Jul 2019 at 5:41am |
I would guess that it is a fl40 or fl50 forklift with the 153 buda. The data tag should be on the dash in the middle of the gauges.
Jim.ME
Posted: 12 Jul 2019 at 5:49am |
1-3-4-2 is the engine firing order. That maybe an Allis G153 (Buda 4B-53) engine.
As DiyDave posted HUS would be for Hussco, a company that manufactured that valve. The valve is part of the hydraulic system not the engine. The tag you posted is an Underwriters tag as to the machine's fire rating. I don't see that that will be much help in ID'ing the forklift. Would you be able to get some more photos of the engine? Get a lower angle and a bit further back to show better side views. Better lighting will help as well. Also a couple good shots of the valve cover and water pump may help. Some lifts had tags on the dash area with capacities of the lifts, etc., below is a sample of one from the web. Comparing photos of AC forklifts from the web to yours, it looks like an FP series.
Posted: 12 Jul 2019 at 6:26am |
WOW that's the gas version of my Buda dieselled lift ! I've yet to find a svc manual though 'liberatedmanuals.com' have 100s of them..... Both gas and disel engines share a lot of same parts ! Brakes are 'fun' to deal with,though I made a 'lift carrier' to do that. Only get 9' of lift and my 2nd floor is 10', sigh. That back chunk of cast iron is about 4000#, the smaller one blocking the hyd pump is about 300# !!! That needs to be removed to change fanbelt.... GREAT machine though, can lift 5000# easy, 6000# bit of a grunt. Check the Carden u-joint between tranny and diff ! odds are nobody ever greased it. ticking timebomb. I'll change mine( underneath job) when it breaks.... Jay
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Posted: 12 Jul 2019 at 3:53pm |
breaks...." Check what it might hit if that happens before it does. Based on - when I ordered u-joint kits for the shaft in our FA 10 parts bloke said "Just as well you found that. If they let go they usually take out the front cover of the transmission"
