200 power director
200Tom1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Topic: 200 power director
    Posted: 29 Jun 2019 at 5:02pm
Fellows. I think I need to drill the hole in the linkage as stated in the book. I do have a copy of the AC service manual. But it is a copy and the picture is not good. Would anyone be able to post a picture of the linkage where the hole needs to be drilled?   My manual shows the measurements I need to use to drill the hole but not the piece of metal that's needs the hole. Thank you for your help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 5:05pm
You basically drill a new hole forward of the existing hole with 1/8" of metal left between the two holes. YOU WILL HAVE TO GRIND/TORCH above this area to eliminate rubbing of the vertical rod when you get done.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 8:50pm
I think I figured out which rod/ linkage it is. Do I need to tear this linkage completely out to drill the hole? Are we looking at hours to do this? Like I said the book I have is a copy and pictures are bad. Again thank you guys.
Dave H (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Jun 2019 at 9:07pm
no  remove the pin on the valve and the vertical rod, then turn the linkage down to drill it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 200Tom1 Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jun 2019 at 2:47pm
Thanks guys. Gonna do this tomorrow evening.
