HD6B Fuel Injector external leak.... |
rhead
Joined: 08 Jan 2019 Location: ann arbor mi Points: 21 |
Topic: HD6B Fuel Injector external leak....Posted: 27 Apr 2019 at 6:04am |
I have a PSB 100EH injection pump that is working fine....just a small external fuel leak coming from the operating shaft. Are there any parts books/lists available online to see if there is just a simple "o" ring or seal that I could change by removing the cover? Or is this a "Authorized Repair shop only" fix? The pump work well, just doesn't start without a small shot of Ether. Any fix for that?
![]() Note picture is counterclockwise 90 degrees
Joined: 14 Sep 2009 Location: Hermann, Mo Points: 35757 |
Posted: 27 Apr 2019 at 7:49am |
Look up your most local injection shop and ask if they show the listings on the PSBs, should be a shaft seal not just an O-ring. My 7G needs a little whiff below 50 degrees, is due to being worn out. Needs pump, nozzles gone thru and the engine overhauled to get compression back.
rhead
Posted: 27 Apr 2019 at 4:26pm |
I found the parts / service manual on AMBAC and found that I could take the shaft out with out things flying out of the injector. Removed the cover and found that the cover/seal was broken and has major wear. Both the cover and the shaft need replacement. Part No. BG 904 Plate/shaft bearing and SH 901a shaft and BL 901 Lever/stop operating shaft. Anyone know where to get these parts? Anyone know of anyone with core pumps that they may sell part off of?
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Posted: 27 Apr 2019 at 5:03pm |
gemdozer
Posted: 28 Apr 2019 at 12:23pm |
I have the complet injection pump PSB and have a spair lever with cover and likage and rear gasket is on.
rhead
Posted: 28 Apr 2019 at 7:21pm |
I’m interested. Can you email me and I’ll send a list of the parts per the diagram
rhead
Posted: 28 Apr 2019 at 7:52pm |
I have been getting advice that I should have the pump gone through because of the lack of smoke.....at start up.....which they said was a sign of a lack of fuel. Any one have a contact for a rebuild shop that I can send it to? Also, should the injectors be gone over at the same time. The dozer runs great once it is started with ether. I'm in the Detroit area although I can ship anywhere.
