Question on HD 16 tranny |
jerbob
Topic: Question on HD 16 trannyPosted: 18 Mar 2019 at 12:44pm |
Good Morning.
Next project on my list of repairs will be sorting out why Reverse 1 pops out and won’t stay in. I have reviewed all the advice you passed on earlier and had a question or two. 1. To look at shift forks and be sure all bolts are tight and in place, do I need to drain the transmission fluid to take cover plate off to inspect forks and bolts? 2. As my 16 uses same oil for steering, transmission and brakes, is it possible that just draining the oil out of bottom of transmission case won’t drain 100% of the total system oil? 3. On my tractor 1,2,3 and R2 work fine. For R1 it goes in fine with normal clutch action but as soon as clutch is disengaged, it pops right out. If you try to hold it in it will shake your hand apart. I am going to take shift lever apart and look for anything out of place in the connections first. Thank you for your thoughts on this. I do have all the manuals so that’s good. |
gemdozer
Posted: 18 Mar 2019 at 4:24pm |
I tink you need to drain the transmission before removed the side inspection plate and stering cluch and brake should't used the same oil and you will have to change the first and reverse gear.
jerbob
Posted: 18 Mar 2019 at 5:33pm |
Thank you. My manual says Brake, Steering and transmission all use common sump. Have HyTran in it right now.
jerbob
Posted: 19 Mar 2019 at 9:36am |
Thank you for your advice.
I have attached the pages our of my manual on servicing my 16DC and in the book it says that Steering, Transmission and Brakes share common system. I would like to confirm I am understanding what I have read and so I have attached the pages out of my original manual that came with my tractor that lead me to understand that these systems shared a common sump or oil supply. My tractor serial number is showing my baby to be a young 1961 mode if that helps. ![]() ![]() Thank you for any additional clarification and advice. |
CAL(KS)
Joined: 18 Sep 2009 Location: Chapman, KS Points: 3804 |
Posted: 19 Mar 2019 at 10:55am |
you have a wet clutch/brake machine with pressure lube trans should all be same oil like you say. i cant say for sure if you would need to drain oil to remove the side cover. try running a tape measure down the side of trans and compare with oil level on dipstick tube. if you do need to drain i doubt that the steering and clutch release system will all bleed out. you either have worn engagement cogs from years of use or its possible the fork has moved on the shaft not allowing full engagement, thus kicking out.
gemdozer
Posted: 19 Mar 2019 at 12:01pm |
If you have the wet brake your transmission and stering boster and brake use the same oil and you should't need to draine for checking.
jerbob
Posted: 19 Mar 2019 at 12:04pm |
Thank you Cal. Good ideas. I’m pulling the gear shift lever to tighten up the flip and see if I find any smoking gun there. In my original parts manual that came with the tractor, a previous owner had underlined a couple of gear shift parts. One is a shift lock bushing. Might be something he replaced at one time. Not sure what that part does but will send pic and see if someone can tell me what this part might impact on the shifting. |
jerbob
Posted: 19 Mar 2019 at 12:54pm |
Here is a pic of the part a former owner may have ordered or replaced. Its item #35 in the parts page and called the "Boot Locking Plunger". Don't have clue what it does or is and what if any impact it may have if defective it would have on my popping out of first reverse great. By the way, when it pops out it is not when tractor is in motion as what happens is when you shift it into gear it goes right in first reverse, then when you let the clutch out it pops out. No noise just won't stay in. If you try to Hold it in place with the clutch not engaged and then hold in while you release the clutch, it will rattle your hands off and you cannot hold it in place. Here is a pic of the part if it helps anyone to be able to tell me in the shifting level functions, what it actually does.
![]() ![]() ![]() Thank you for any feedback and information team. |
CAL(KS)
Posted: 19 Mar 2019 at 1:20pm |
that just keeps oil from leaking on the interlock plunger. you should not be able to shift gears when the main clutch is engaged, releases plunger when main clutch pulled out.
jerbob
Posted: 19 Mar 2019 at 2:40pm |
Ok and thank you Cal. It looked like a rubber type of plug or seal. Just thought I would check on it. You are also correct, I cannot shift while the clutch is engaged. Also the shifting lever is not the loose and has no slop in it that allows you to rotate it in the least. Now that the weather is getting better, I will be pulling the old girl out of the barn and onto the cement so I can take the shift lever out and check on all the connections. In a past conversation and links between you and ACMel I saved, it showed just how messed up these old shifters can get. I will pull out and inspect pins and bolts for out of spec and rust deterioration. Will post pics as well. Thank you again Cal. All in all I am lucky. 1,2, 3 and R2 work like a champ with not issues. Makes it a little hairy backing into my barn. The blade has clearance on each side of a foot. |
jerbob
Posted: 24 Mar 2019 at 8:40am |
Thanks Cal.
Warming up here in Michigan and able to crawl under the 16 to find leak. No leaks detected around sprocket, any of the covers. All dry but oil still leaking and puddling directly under the track and under the sprocket. As I said sprocket seals and all covers are bone dry. I can’t see between the final drive housing and rail as the bolt on rock guard is blocking my vision and it appears to be leaking down that area. QUESTION ... Can I unbolting the rock guard from the final drive housing without splitting track. Bolted on with half s dozen bolts. It’s a crescent shaped piece of steel that protects the rail and roller. |
CAL(KS)
Posted: 25 Mar 2019 at 8:05am |
yes
jerbob
Posted: 25 Mar 2019 at 9:59am |
Great and thank you Cal. Steam and power washing this weekend. Will pull the rock guard off and see what I can see..
The cap covers on the final drive on both sides of the sprocket are dry as well as the other covers above it. No sign of a gasket or seal leak. At least in my last few inspections. Thanks again Cal. As hard as someone was on this tractor I would not be surprised to find a hairline crack on bottom of final drive casting. |
