B sleeve O-rings
Denis in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Denis in MI Quote  Post ReplyReply Direct Link To This Post Topic: B sleeve O-rings
    Posted: 07 Sep 2010 at 3:12pm
Are the sealing rings for the bottom of the old 3 1/4 bore sleeves square cut or just plain O-rings smashed into a square groove and where is the best place to get them from.
Thanks in advance for any help or ideas,
Denis
1938 B, 1945 B, 1941 IB, 1949 C, 2 1938 WCs, 3 1950 WDs, 1951 WD, 2 1955 WD45, 1957 D-14
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 3:21pm
The cross section is round on what I have seen. They may look square after 60+ years in the groove.
Jeff Z. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeff  Z.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2010 at 3:25pm
Lube them up good with liquid dish soap.
Do not use motor oil or grease made from oil.
firebrick43 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote firebrick43 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Sep 2010 at 10:28am
The cats meow for lubing rubber is silicone grease, sold in a small squeeze tube at Napa or other auto parts stores.  A little goes a long way, won't harm rubber and is slicker than hog crap on a wet pasture.  Don't get it where you plan to paint later on, ie wash your hands good after lubing up the orings and slipping them on the sleeves.
gcalent View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gcalent Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 9:49am
Vegetable oil is OK, but no petrolium based products
Pullin With AC
Robert Mull Georgia View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Robert Mull Georgia Quote  Post ReplyReply Direct Link To This Post Posted: 09 Sep 2010 at 1:45pm
I have used dish washing detergent. I have not figured out yet what protects them from the engine oil in the crankcase. Go figure.
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Sep 2010 at 9:03pm
The story as was told to me....No petroleum lubes because they turn to carbon under heat and time which then abraids the oring causing it to fail.Oil from the crankcase isn't encased in the groove so not a problem
