wc war time rear end
patrickmull View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Topic: wc war time rear end
    Posted: 12 Jan 2011 at 7:43pm
i have a wc steal rear end what year would it be
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 7:44pm
 What is the seriel number?
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 7:50pm
i do not have it with me did they use the press steel rear end more than one year
Gary in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jan 2011 at 8:43pm
1944 is one of the years
Serial number  WC132138S
Edited by Gary in Texas - 12 Jan 2011 at 8:48pm
DouginIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DouginIL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 5:40am
I think they were used in 1944, 1945 and a few in '46. I have a '45 with one.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 8:02am
I have a 45 with cast iron rear end and Dad has a 46 with steel. I think they built what they could when they could.
Wink
I am a Russian Bot
Brian Ahart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Ahart Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jan 2011 at 8:20am
Ed Mills has collected a wealth of SN data on the WC tractors, including wartime production. Some of his data is posted on Bryan Smith's website. I personally know of a late '46 WC with the wartime steel rear end (SN 150xxx). When I sent that data to Ed several years ago, that was the 2nd highest wartime WC he had on record (the highest SN was 1535xx).  I am not sure if he posts here, but there was a user named Matt over on YT who posted that he has 153387 S.
A-C Weight ID reference and other goodies at brianahart.net
MLGoodwin82 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MLGoodwin82 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 2:29pm
Yes Brian, I'm floating around here every once in a while.  Still have that one.  Right now she's freezing her butt off out in the barn with a flat tire.  Need to fix that and probably clean the carb out.  Was acting up pretty badly this fall.  Has a cultivator lift on it, wouldn't mind finding a set of cultivators for it.
TomMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 5:30pm
Mine is a 1944 s/n 131742 and I have not seen one older yet.  Does anyone know what the database has for the first one?
OrangeKiwi(NZ) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote OrangeKiwi(NZ) Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2011 at 7:27pm
WC 163161S 1947 resides in the South Island of New Zealand
Post Options Post Options   Thanks (0) Thanks(0)   Quote patrickmull Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 7:16am
mine is a 1946 the # is WC148911S i believe it hard to read got to get it in and do some polishing on it
1946WP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1946WP Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jan 2011 at 9:21pm
mine's WC133089s. a 1944 with a david bradley loader.
Preston230 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Preston230 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2018 at 5:01pm
I just got a WC home with a war time rear end and the numbers appear to say wc540503. The first number is a 5 and not a 3. The picture is harder to tell.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Preston230 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2018 at 5:09pm
Actually by looking at the other guys post that's a S so it says wc54050S
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomMN Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2018 at 5:36pm
I would guess if it was cleaned up real well it would be WC134050S That is the only serial number that would make sense, making it a late 1944 model.
If it were WC154050S it would be a 1947 after there were no steel rear ends.  And WC54050S would be a 1937 long before that style rear.
Edited by TomMN - 26 Dec 2018 at 5:41pm
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2018 at 7:06pm
got the 45 with cast center wheels i thank there geared a little better' also.
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2018 at 8:25am
I picked up a '45 a while back. Really good tractor over all. I will be sporting the arch frame wf and maybe foot brakes.
This page was generated in 0.172 seconds.
