Replacing a well pressure tank
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Topic: Replacing a well pressure tank
    Posted: 30 Nov 2018 at 7:08pm
Gonna replace my pressure tank tomorrow for the well system, my question is once I get all the plumbing done , should I fill the pressure tank with water before putting air pressure to it then drain , or just put air pressure to it , then fill?
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 7:14pm
Instructions usually come with the tank.
If I remember right, for bladder tanks, you add air until the pressure is 5 lb. below turn on pressure. Then turn the pump on.
Dusty
weiner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote weiner Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 7:19pm
I believe they are already set at the correct pressure.  You want the bladder tank to be set lower than the pump shut off switch is.  I just put one in and the pressure in the bladder tank was preset at 37 psi and my switch on the pump is 40 psi.
Real heros wear dogtags, not capes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 9:16pm
Dusty
YUP^^
Since different mfg's make different tanks, when all else fails, follow the instructions...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2018 at 10:57pm
If all else fails OR you want to know for sure, PM Les or wait for him to come on here and see this thread.  He told me explicitly (step by step) once and he knows his chit about this,,,,,,,,,,,,,
after all, he's a well driller..
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2018 at 2:27am
my tank came pre-pressurized years ago. I remember the well co kept checking the pressure and kept releasing air from it.
