2800 engine in a wd45 |
Mufflerboltz2
Topic: 2800 engine in a wd45Posted: 07 Nov 2018 at 5:04am |
Ok fellas, I use to post here a few years back but lost/forgot my sign in name and password.
So here it goes, I'd like to know what it takes to drop a 301 diesel into a wd45 chassis. Obviously I'd use a regular wd45 instead of hacking up a wd45d. Is there a special flywheel and adapter plate? I know the hood would need to be extended amd the radiator moved, does the frame to be added onto? I guess what I am asking is what do I all need to round up amd what to expect! Thanks! |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7630 |
Posted: 07 Nov 2018 at 9:10pm |
It is far from a "drop in"! Parts are one thing. Fabrication is another.
Mufflerboltz2
Posted: 08 Nov 2018 at 7:40am |
All the fabricated parts that need to be made are not an issue. I'd like to know what are parts that can be used like a flywheel/clutch setup. If an adapter plate needs to be made, that I can handle.
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2481 |
Posted: 17 Nov 2018 at 5:31pm |
![]() You might call this guy.![]()
Posted: 17 Nov 2018 at 7:01pm |
Some people are just too talented...……...
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4063 |
Posted: 17 Nov 2018 at 8:53pm |
yes that is a clean job, would the drive train ever hold up farming with it ? would be hard not to over work with bigger implaments or not shifting down
Posted: 17 Nov 2018 at 10:10pm |
So, to me it looks like he's using a WD45 diesel starter and maybe a WD45 diesel flywheel?? that has been modified to fit the 2900 crankshaft ?? The 2900 backplate has been reshaped and drilled to bolt up to the WD45 bellhousing. Frame has been lengthened. Hood has been raised taller. Don't know what he did for a radiator.
JC-WI
Joined: 11 Sep 2009 Location: wisconsin Points: 34602 |
Posted: 18 Nov 2018 at 1:29am |
Here was a thread Lynn Marshall had at least another 7 pictures of the building of the WD65 Turbo Diesel... But alass they are gone.
mf440
Posted: 26 Dec 2018 at 8:40pm |
The wd45 diesel flywheel bolts to the 301 crank with no mods, same oil seal. Just lay a wd diesel engine plate on the 301 plate and mark the holes you need and the shape.
190xt llss
Posted: 04 Jan 2019 at 11:21am |
It’s not that hard I did on a wd I have all the adapters and you use the wd starter. You can put the 201 or the 301 in with what I made. The hardest part was putting the bubble in the hood to clear the turbo
190xt llss
Posted: 04 Jan 2019 at 11:26am |
I might add I used the wd flywheel and pressure plate also
steve fischer
Joined: 11 Jul 2011 Location: sleepy eye mn Points: 1018 |
Posted: 04 Jan 2019 at 6:19pm |
doing one right know , hard parts so far has been the steering , front shaft goes into diesel pump area , built jake shaft and made frames about 5 inches longer ,have pictures but need help getting on here , can text to someone thanks Steve
