fuel leak. on hd 4
pinball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Topic: fuel leak. on hd 4
    Posted: 12 Sep 2018 at 4:14pm
i have a short metal line that has rubbed a hole in it. it is on the return line from the governor to the fuel tank on an HD4 ALLIS CRAWLER. Went up town and no one could make me a line. Don't know how much pressure it holds but would I just be able to get a rubber fuel line and just splice it in or do you think it wouldn't hold the pressure. thanks norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2018 at 4:34pm
I don't remember what they looked like. Most are just steel lines with rubber grommets. Not much pressure . Would brake line work, not sure of size. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2018 at 4:37pm
Just went and looked at mine. They have rubber flex line at the bends. So I think a longer piece would work. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2018 at 6:31pm
mine has the flex hose until it gets to the frame work then its a steel line. problem is the steel line was rubbing and got a hole in her. thanks norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2018 at 7:05pm
Norm, just slide a piece of hose  and two clamps over the steel line. Clamp at each end to cover leak. Problem solved. HTH Tracy
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 12 Sep 2018 at 9:00pm
sounds like good advice. thanks norm
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2018 at 7:44am
take the line off, buff the area around the hole.  clean it well with brake cleaner or ether and braze it shut.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2018 at 12:04pm
thought about that to but the hole is right next to the fitting so if I brazed it I woudnt be able to turn the fitting. thanks norm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Sep 2018 at 12:26pm
no that wont work then.
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2018 at 5:08am
Norm/All:
Search HS50 Steel Tubing  Plymouth Comapany- Lenz Company for the tooling to make any flares needed.
Make your line and fix.
Good Luck
Orangeman
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2018 at 8:15am
I think it was mentioned earlier however you could replace with stainless steel braided hose and it would last another 30 years, or a trip to any auto parts store for steel tubing or copper and a pipe bender and flaring kit. It takes what they call a double flare I believe nuts it's simple. On my 16 I replaced the fuel with braided hose and used copper tubing for the hard connections. You can also take your steel tubing off in one piece and then you can have a replacement one made by any brake shop or do it yourself. Satisfying when I did it myself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2018 at 7:20pm
Put in a fuel proof rubber hose if it's the return side - problem solved
Post Options Post Options   Thanks (0) Thanks(0)   Quote pinball Quote  Post ReplyReply Direct Link To This Post Posted: 14 Sep 2018 at 10:53pm
I put a rubber hose on it today. works fine. finally got my fuel leaks stopped for now. thanks norm
This page was generated in 0.336 seconds.
