AC C steering linkage
rjamann2004 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rjamann2004 Quote  Post ReplyReply Direct Link To This Post Topic: AC C steering linkage
    Posted: 10 May 2018 at 10:27am
How do I remove steering shaft from ball joint ends on C model?
pumpkinman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2018 at 4:03pm
Get a TIE ROD - BALL JOINT PICKEL FORK  A LARGE HAMMER and some HEAT
        KENT
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 10 May 2018 at 9:04pm
Are you trying to change the tie rod ends or the drag link ends. Tie rod ends a pickle fork and big hammer. Just buy new tie rods there always so rusted together usually you destroy them. Drag links need to be replaced as a unit there are no replacment ends.
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2018 at 5:51am
You can buy weld on tie rod ends.  As long as you find the right ones, you can cut and weld new ones on the drag link.  Tie rod fork/pickle fork will separate them.
AaronSEIA
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 11 May 2018 at 8:51am
In a pinch without a pickle fork you can turn the nut around and put it on flush with the end of the stud and hit it with a 10 pound hammer. If the nut is flush with the stud so you hit both at the same time it will not damage the threads. The front you can turn to have the end forward. At the steering box you would have to put a sledge or a heavy piece of steel on the nut and hit the steering arm. A pickle fork is best if you have one.
