AC Single Row Planter Part
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Topic: AC Single Row Planter Part
    Posted: 27 Apr 2018 at 9:22pm
This planter has a Solid Rubber  single rib packer wheel that drives a 14 tooth sprocket pinned to the axle. A flat link chain drives a 10 tooth sprocket on the seed hopper.
I would love to find a 16 or 18 tooth sprocket  to hopefully drop  pea seed  closer than 6 inches using the 14 tooth drive sprocket.     Sprocket Bore size is 3/4 Inch
 I have no model #  or Manual for this planter.          Sorry no Pics
   See a very close pic of what I have and need a 16 tooth packer wheel Sprocket for, Mine is set up for 3 point hitch like this ebay item #202288050441  With a much heavier frame
    When I say PEAS I'm talkin COWPEAS
Edited by Ken in Texas - 27 Apr 2018 at 10:06pm
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2018 at 8:19am
Can you switch the two you have?  Seems that would get close to the same results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2018 at 5:41pm
Ken, have you tried Shoup catalog?  Sometimes its easier to match things up by sight, and their catalog has lotsa pictures.  Mostly JD and Kinze parts, but lots of 'em...
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2018 at 9:21pm
what plates (seed) are you using? 16 or 24 cell?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2018 at 10:04pm
24
      A 10 tooth driving a 14 will slow down the seed plate. Plastic
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2018 at 10:21pm
I have a 18 tooth drive sprocket on its way here from Schmidt & Sons Equipment in Kansas.  My guess was going from a 14 tooth to a 18 driving a 10 on the seed hopper with a 24 cell plate will place cowpeas close to perfect.
