AC 5050 brakes
Donkey376 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donkey376 Quote  Post ReplyReply Direct Link To This Post Topic: AC 5050 brakes
    Posted: 15 Apr 2018 at 6:19am
Has anyone ever attempted to change the brakes on a 5050? I have the manual finally and it doesn't look too bad....but I was wondering how bad those pivot pins come out? I don have access to torches anymore....
bozrae View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 6:37am
It's likely you'll need a torch unless your pins aren't rusted to bad, then you may be able to just pull them out.I did both sides of the brakes on my 5050 a few months ago, but I did end up using a torch to cut out the old bands and then pounded out the pins with a punch.
D15D, D17G, 170G, 175D, and two 5050FWA
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donkey376 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 6:42am
Didn't happen to take any pics did you? I've never done anything like this before....I'm used to my Farmall Cub lol.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 8:35am
The pictures I have may not be real useful, but here they are. The side shown in the pictures was the most difficult to remove because they were filled with muddy, rusty gunk. The brake lever shaft needs to be removed first and I had to heat the tapered bolt holding it onto the lever also.  Putting the brake bands back in can be tricky, but with patience it is possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 8:38am
A good source of parts I found is: Ricks Ag Parts LLC
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donkey376 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Apr 2018 at 12:54pm
Those are helpful! The only tractor experience I have is with my Cub I use to mow our land...
What'd you use to yank the finals? Engine hoist?
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 17 Apr 2018 at 6:14am
The 5050 is a little more complex than a Cub, but once its back in working order you'll probably find it a good usable tractor.
I used an engine type puller or 'cherry picker' to remove the axle housing. I did find one picture with the chains attached to the housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donkey376 Quote  Post ReplyReply Direct Link To This Post Posted: 18 Apr 2018 at 10:32am
Its def a different animal than the cub! Thank you very much for your help...I'll tackle it soon.
Dan Hauter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dan Hauter Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2018 at 8:58pm
I have a 5050 and so does a friend.  Good, tough little tractors.  They're actually Fiats.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donkey376 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 2:07pm
I love mine but just wish I had more time to tackle it...the wiring is completely butchered. Someone put a newer 1 wire alternator on it and nothing really works (ignition is bypassed too)...Sometime Ill get around to rewiring it then go from there.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 3:31pm
They do seem like rugged tractors. I've been into the wiring on both of my 5050's and was able to get everything working again, but the manual doesn't have the greatest wiring diagram. At some point they changed to a different style alternator with a built in voltage regulator, but the diagram is not updated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Donkey376 Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2018 at 3:34pm
There's no external regulator or fuse box on mine...just a complete disaster and I really have no idea where to start lol
