Oil pressure Allis C
John426 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Topic: Oil pressure Allis C
    Posted: 02 Apr 2018 at 3:00am
Hi
i have a problem of oil pressure with my Allis Chalmers C.
When I'm on a steep climb (uphill) or a banked, the oil pressure becomes very low, close to zero.
Then returning to flat, the pressure will gradually go back to normal position.
The strainer was cleaned about 100 hours ago and the oil filter changed 100 hours ago too.
Where could this problem come from?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 4:34am
The pickup tube is placed correctly, I presume?
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 7:00am
Is the oil level where it should be?
AaronSEIA
Larry in NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Larry in NC Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 8:12am
That is strange, do you think the gauge could be bad?  I assume that the tractor does maintain good oil pressure when idling?
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 9:11am
Shop manual may have a hint. My guess would be low oil level in the crankcase.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Leon n/c AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 3:32pm
If the oil shows to top of full mark I would add half quart see if it still goes down add the other half quart and try again.  Like Gerald I think the oil level is low or the screen is too high. Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote John426 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2018 at 12:34pm
The oil level is O.K . Today i remove the cranckase, and i see that the pcik up tube was not in the coorect position . Too high.
Now it is ok. Thanks a lot for your help
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon n/c AR. Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2018 at 1:44pm
Glad to hear you found the problem. Super nice looking tractor and mower. Leon
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2018 at 9:24pm
Nice looking!!!  Glad you figured it out.  They ARE simple.
Looks like you have some kind of horn hooked up and what's with those headlights?  They look oversize and Yellow bulbs?
This page was generated in 0.075 seconds.
