Ac 200 heard up
DLPETERS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DLPETERS Quote  Post ReplyReply Direct Link To This Post Topic: Ac 200 heard up
    Posted: 01 Apr 2018 at 6:39pm
I just bought an allis chalmers 200 that before I bought it I was told it probably needed a head gasket because it over heats but only under load !! I drove it home which took 3 hours and the water temp just barely reached the beginning of the green on an AC water temp guage ! There is no visible leakage on the head gasket on the out side and the tractor runs great ! Does anyone have any ideas ?
DLPETERS
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2018 at 6:46pm
Yeah, if it ain't broke; don't fix it! But seriously, watch for excess pressure, or bubbling in the radiator, look for anti-freeze in the oil, and oil in the anti-freeze. Monitor everything closely, and run it. Darrel
grinder220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote grinder220 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2018 at 8:14pm
Welcome to the forum Don,you must have bought the one from Baldwin? If the head gasket is leaking it will cause the radiator to bubble over under load. The turbo builds boost in the cooling system when under load. My 8550 did the same thing last year. No trace of coolant in the oil but get it under some pull and out the cap it goes.
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2018 at 8:45pm
Sure it's not a dirty radiator? My experience with blown head gaskets, the engine will get hot regardless of load, as hot gasses are getting into the cooling system. If you drove it for three hours, and it didn't get hot, or blow coolant out the radiator, I would be looking else where. Just my two cents.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2018 at 9:03pm
Our 200 did the same thing. We took the bottom an top hosees off and the radiator was pluged. We ran garden hose into the bottom to like back flush it. Took some time to get it opened up. We took the thermostat out so that it would flush around a bit. And put it back in. Works fine now.
And welcome to the forum
Edited by Mikez - 01 Apr 2018 at 9:05pm
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2018 at 9:19pm
Better chance of dirty radiator inside or thermostat than head gasket.    MACK
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2018 at 10:16pm
Are the fan belts tight enough and not worn out and running on the bottoms of the pulleys?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2018 at 10:27pm
Either way,I would pull the radiator and go get it boiled and checked out by a competent radiator shop.Old enough to need it!
drobCA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote drobCA Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2018 at 10:30pm
welcome and thanks for asking a question that others like me can learn from.
these guys DO know their stuff!
3 Ford 8N's I loan to neighbors, but the '52CA, '41B and little B1 I do not.
JayIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JayIN Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 8:01am
Yeah. I would boil the radiator first and go from there. 200 is a great tractor!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 9:23am
thats why you only use disttiled water when you change coolant
Post Options Post Options   Thanks (0) Thanks(0)   Quote DLPETERS Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2018 at 11:06am
Yes it is the one from Baldwin ! It sat for 15 or 16 years ! And yes I'm new to the forum and already can see there is a wealth of information on it that's awesome
