D14 Ignition Timing Mark
r8f1k View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote r8f1k Quote  Post ReplyReply Direct Link To This Post Topic: D14 Ignition Timing Mark
    Posted: 10 Mar 2018 at 4:43pm
I tore down my 57-58 D14 in the last month.  Took it all the way down to the diff.  Now I am having trouble getting it to start.  Engine ran great prior to disassembly, however, everything leaked.  Took the opportunity to reseal, regasket, and repaint the tractor.  The engine is nice and tight, but I can't get her to start.  Using the timing marks on the flywheel, do I set the timing based on the marks when visible in the access hole in the bottom?  Or when the marks are visible in the bell housing hole, the size of a quarter, on the right side of the tractor?  There is a mark on the crankshaft pulley, but I see nothing that indicates DTC for it......Any thoughts?
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2018 at 5:36pm
Use the small right hole on the right side of the housing. Use the center mark, make sure #1 cylinder is on the compression stroke. Then set rotor to point to which ever distributor cap terminal is #1 cylinder. On mine it is the forward terminal closest to the block, however yours could be using another cap terminal for #1, depends on how it has been set up.
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
Post Options Post Options   Thanks (0) Thanks(0)   Quote r8f1k Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2018 at 5:40pm
Do you use the FIRE timing mark for cylinder no.1?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2018 at 5:47pm
On my 45 you use the fire mark with a timing light and high idle.It's on the bottom but same principle. Adjust distributor accordingly. TDC will be too retarded.
Edited by SteveM C/IL - 10 Mar 2018 at 5:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2018 at 5:50pm
Use the center mark to set initial timing, the fire mark is to use a timing light at over 1000 rpm to check for advance working. At least thats how I remember it. I know if you use the center mark as I described will run. Did one not to long ago. Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote r8f1k Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2018 at 10:05pm
Got it, I will give it a whirl.  Right now I am waiting on a new starter.  I shattered the nose cone on my starter.......never had that happen in 25 years of working on tractors.......I will post once I get it done!
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2018 at 10:46pm
If you can't see the timing marks or don't have a timing light you may want to try another method. Remove the spark plugs and rotate the engine with your finger over the #1 spark plug hole. Stop when you feel the compression pressure. Now insert a length of wire (or an electrical tie) into the hole until it contacts the top of the piston. Continue to rotate the engine until the wire is pushed out the furthest. Your engine is now at TDC and should fire up. Adjust the timing by ear; rotate the distributor counter clock wise until it smooths out and continue on until it starts to "load up", then rotate the distributor the other direction until it runs smooth and continue on until it loads up again. Turn the distributor back half way between the two points that the engine loads up and the engine is timed. Best if done with the engine at 1/2 to 2/3 throttle; altho you can do it at idle then redo it again at operating speed.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2018 at 9:51am
Too many people don't seem to understand that there are 2 separate upstrokes of the piston in a complete cycle. One stroke is for exhaust and no engine will run if you time it to the exhaust stroke.
 The other upstroke is with both valves closed, causing compression and that's where the spark at TDC makes for a running engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote r8f1k Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 3:40pm
Ok, runs like a champ.  Timed it up nice with a timing light and the "FIRE" mark.  However, I have a new problem.......The clutch is VERY short now.  I put a new one in and I have a very long clutch pedal travel and a very short interval where it does anything.  The other problem, is that once you put it in gear, she starts to roll.  You barely need to move the clutch pedal and it starts to roll faster than it should.  I have the clutch rod adjusted to the longest it can be (looking through the access hole in the bell housing and watching the threads) but am I missing something?  Do I need a longer clutch rod?  I have heard adjusting the fingers on the pressure plate, but I have also heard that is a No-No.  Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 4:13pm
The length of the clutch rod does nothing for you. If you can get it in gear OK, I'd live with it because as it wears that distance will improve. If you can't live with it, change the 3 fingers 1/8" closer to the throw out bearing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote r8f1k Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2018 at 4:31pm
Do you need the special thin wrenches to adjust the fingers?  Is it possible that I bent the clutch disk?  I had this problem about 10 years ago on a Willys station wagon that fought me while putting the engine back in after a new clutch.  I had to dump the clutch a few times before it wore itself straight.  What concerns me still is that the pedal is LOOOOONG and the engaging is SHORT.  Any procedure to follow for adjusting the fingers?
Post Options Post Options   Thanks (0) Thanks(0)   Quote r8f1k Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2018 at 10:11am
Adjusted fingers towards the throwout bearing and all is now well.
Thanks EVERYONE for your help!
This page was generated in 0.048 seconds.
