AC C Wheel Bearing
BART View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BART Quote  Post ReplyReply Direct Link To This Post Topic: AC C Wheel Bearing
    Posted: 06 Mar 2018 at 2:06pm
Does any one have the part number for the outer{large] wheel bearing. I would like to have the bearing before I take it apart so my shop is nt tied up Thanks Bart
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2018 at 3:07pm
this is what I have listed.....for the B-C tractor
Front Wheels:
Seal: AGCO #70207365 (Felt) (or 1.5 ID, 2.5 OD, 3/8 thick lip)
Outer Cup - Timken #09195
Outer Cone - Timken #09074
Inner Cup - Timken #15250
Inner Cone - Timken #15118
Edited by steve(ill) - 06 Mar 2018 at 3:08pm
BART View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BART Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2018 at 6:11pm
Forgot to mention rear wheel Sorry Bart
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 12:34pm
Rear Axle/Final Drive:
Axle Seal- CR #25043
Axle Speedi-Sleeve - CR #99248
Outer Axle Bearing Cone - Timken #368A  ( bottom shaft)
Outer Axle Bearing Cup - Timken #362   ( behind the wheel hub)
Inner Axle Bearing Cone - Timken #14138A
Inner Axle Bearing Cup - Timken #14276
Pinion Seal: CR #13900, National #450456
Pinion Bearing Cone - Timken #14138A  (top  shaft)
Pinion Bearing Cup - Timken #14276
Edited by steve(ill) - 07 Mar 2018 at 12:43pm
BART View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BART Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 4:36pm
Thanks a lot for all the help.Bart
BART View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BART Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2018 at 4:37pm
Steve were in IL are you located?
This page was generated in 0.041 seconds.
