Spring Trip Mounted AC Plows
WNYBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Topic: Spring Trip Mounted AC Plows
    Posted: 23 Feb 2018 at 9:24am
I have a set of 3 bottom mounted spring trip plows.   One beam trips too easily.   Book says to put a washer in it.   I am afraid I will break something trying to get it apart.  Is there an easier way?????
Bill
JimWenigOH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JimWenigOH Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2018 at 6:00am
I don't know of an easier way.  I'm  a "do it by the book" type of guy most of the time. At least if something should break there are lots of plows at my salvage yard where I can get parts. If the job gets done right the first time, that's one less monkey on my back is the way I look at it.  Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2018 at 6:09am
I also believe in doing it right or don’t waste your time.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 24 Feb 2018 at 10:52am
Without digging into all my books, When I replaced everything in one of my plows I had the same trouble. Two books said differnt. One of the books said to just tighten up on the main pivot bolt a little bit causing some extra friction on the beam. It didn't take much
