ac 160
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Topic: ac 160
    Posted: 11 Feb 2018 at 9:04am
I put on a new hyd.pump because the 3point arms was going up real slow.I clean all filters change the oil and still with engine running at high speed the 3 point arms with the plow on comes up slow can any one help please. Thanks John
acjwb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote acjwb Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 1:25pm
John, There is a small black knob under the seat that adjust the flow of oil I think. Turn it to see if that would help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 2:37pm
I checked that nothing change
TimZ(TX) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimZ(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2018 at 5:32pm
Did you check the screen on top of the transmission.  There are four bolts to remove and pull the housing out. that being clogged really slows it down.
2-B's,CA,D15,D17,160,2-185's 8010
This page was generated in 0.035 seconds.
