210 Connecting Rod Bolts
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Topic: 210 Connecting Rod Bolts
    Posted: 18 Dec 2017 at 1:23pm
I am inframng a 210 right now.  I did this one some years ago and unfortunately it had a bad incident.  I have always replaced the connecting rod bolts on the 426 cu in engines.  When I just priced them from my AGCO dealer  I was quoted $623 for the 12 of them.  Seems to me that is ridiculous price.  Does any one have the ARP number for them?  Or know a dealer that will sell them for a reasonable price??
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 3:18pm
last I priced they were around 30 for a pair for one rod. Agco could have nearly quadrupled the price, but something doesn't sound right. I can check with my agco buddy!
CALEBnOK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 3:29pm
You can't buy the exact same bolt from arp. Under contract with agco. You will be fine with the standard arp 8740 bolts. They are 170,000 psi clamping force at like 60 ft lbs and like 200,000 at 80ft lbs. I think you go like 85 ftlbs on the agco bolts.
If you have one to pattern off of you can have arp custom build them but dont tell them what they are for (426 allis)
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 4:10pm
I would appreciate you looking into it for me Ed.  Thanks in advance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 6:35pm
remember the part number, so I don't have to look it up?
Dswall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dswall Quote  Post ReplyReply Direct Link To This Post Posted: 18 Dec 2017 at 6:57pm
I can post arp part number tomorrow if someone doesn’t beat me to it. Think they are $65 a set with washers
Dustin in CA
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 7:31am
agco number is 70277489, and come in pairs for one rod, and include the bulletin. I'll find out current price. I see the op is in Canada, so that may affect the price.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 8:20am
Yes that is the correct part number.  I can't imagine there being that much difference between your price and ours here.  They want 4618.65 for the overhaul kit, and they are on back order, lol.  aftermarket for sure is where I will get the overhaul kit from, most likely in your country as well.  A hour drive gets me into Michigan from my house, saves a lot on some parts, not on some others.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 8:20am
should be less than $30 per pair of bolts......$180 per engine.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 8:24am
More than a few times I have seen AGCO prices do this n some things in Canada.  Sometimes they correct it sometimes they don't.  I have learned to always shop around with them.  I have also bought many John Deere parts for much less in The Unite States than in Canada.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 8:53am
my buddy just got back to me, AGCO list is $36/pair, but sold in sets of 6 pair, so $216 for a set for one engine. My buddy is also a howards/reliance dealer.
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 9:18am
ARP number Bolt AR403-1 requires a washer as well 200-8502
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 19 Dec 2017 at 8:11pm
The last rod bolts that I bought from Agco for a 426 engine were stamped ARP. If I remember correctly, Big Bock Chevys were very close to the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dswall Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2017 at 9:39am
AR403-1 is the bolt $6.27
W401-1-2 is the washer $.98
Dustin in CA
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2017 at 11:12am
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2017 at 5:49pm
when my mechanic talked to ARP about my new bolts,the guy on the other end had no info and no listing for AC 426 rod bolts. They do have ARP stamped in them.This was in 09.
Bruce(IA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bruce(IA) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Dec 2017 at 9:05pm
Instructions for Kit # 70277489
 These are for the ARP Bolts
LB0442 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LB0442 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2017 at 2:03am
A while ago I replaced the rod bearings in a 426, no noise just preventative measure.  I used the agco bolts and federal mogul bearings.  Like the instructions say you have to turn the rod/piston 180 degrees.  3 of them were pretty easy, 2 took a little work, but 1 was a bear to get turned.  It seemed to hit on everything before it would go all the way around.  Made a couple of long rods with welded ends on to push the piston/rod up and really helped pulling it back down.  I put clear vinyl tubing on them to keep from scratching the crank.
Still going strong.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CALEBnOK Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2017 at 12:19pm
Originally posted by Acdiesel Acdiesel wrote:
<a id="linkMainImg" style="cursor: default; display: inline !important;"><div id="mainImgHldr" class="img500" title="ARP-743-2250-BOLT-KIT-12PT-5" style="width: 500px; background–image: none; display: inline !important;">ARP-743-2250-BOLT-KIT-12PT-5</a><a id="linkMainImg" style="display: block; cursor: default;">
                                                       <div id="mainImgHldr" class="img500" style="width: 500px; background–image: none;" title="ARP-743-2250-BOLT-KIT-12PT-5">
                                                            <!-- </span> -->
                                                            <div id="vi_zoom_trigger_mask" ="zoom_trigger_mask" style="height: 500px; width: 500px; top: 0px; left: 1px; display: none;">
          <div id="vi_zoom_trigger_mrk" style="top: 190px; left: 190px;">
               <div ="vi_zoom_trigger_msg">
                    <table>
                         <t><tr>
                              <td><b style="display: block; font-family: 'Helvetica neue',Helvetica,Arial,Verdana,Sans-serif; font-size: 12px;">Mouse over to Zoom
Click to enlarge</td>
                         </tr>
                    </t></table>
     <span id="zoom_or" ="zoom_slct" style="height: 207.333px; width: 313.313px; left: 84px; top: 193.5px; display: inline;"></span></a>
<a style="cursor: default; display: inline !imant;"><div class="img500" title="ARP-743-2250-BOLT-KIT-12PT-5" style="width: 500px; background–image: none; display: inline !important;">
</a>
</a>
<a style="cursor: default; display: inline !imant;"><div class="img500" title="ARP-743-2250-BOLT-KIT-12PT-5" style="width: 500px; background–image: none; display: inline !important;">LINK
</a>ARP 743-2250 BOLT KIT - 12PT. (5)
</a>
</a>
</a>
These bolts will work strength wise but the true "rod bolts" have a stepped shoulder and most of the bolt is smaller diameter than 7/16". It steps back out at the threads.
This will affect rod weight balancing.
It might vibrate alittle more but would probably run fine.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2017 at 6:41am
How would those bolts affect rod balance?
Wink
I am a Russian Bot
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2017 at 9:50am
The rod bolts along with the big end of the connecting rods and the crankshaft rod section is way off center of the axis of the crankshaft spinning and so make it unbalanced. Speedy cranks often have counter balance fixed weights to counter the off center weight of the crank and rod parts, but its not adjustable to account for heavier or lighter connecting rod bolts. Slow speed tractor engines often don't have individual cylinder counter weights on the crankshaft.
Gerald J.
This page was generated in 0.115 seconds.
