Flushing Radiator of HD16 tractor
jerbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Topic: Flushing Radiator of HD16 tractor
    Posted: 17 Oct 2017 at 10:27am
Hello Everyone.
First, glad to hear Mel is all right and assuming his family as well. Be safe out here Mel.
Question
I am draining the radiator on my HD16DC, a 1961, and would like to flush out the radiator prior to refilling it. I read in the manual about flushing and cleaning with Sal Soda. Has anyone used any type of radiator flushing cleaning solution on any of your tractors prior to refilling with clean antifreeze coolant? The coolant in the radiator right now looks brown and I want to start fresh and clean.
Is so please advise me. Otherwise I will just flush with clean water and leave it at that.
My thanks for sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2017 at 10:33am
Just flush with clear water, most other solutions have to be also flushed with clear water.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 17 Oct 2017 at 1:28pm
Thank you. And easier. I'm guilty of overthinking some of this.
dustydoo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dustydoo Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2017 at 4:58am
If you can remove the thermostat and reinstall housing the flushing will be more effective . Also if you can flush from top to bottom is reversing the normal coolant flow picking up more debris .
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2017 at 6:41am
Thank you. Good plan.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2017 at 8:22am
I've also used non-suds washing soap. Cleans better and flushes out easier. Lost an oil cooler on my road truck one time and I thought I got it flushed real good. Didn't. Ran it a couple weeks, no issues, and then Oh heck. It had polished the inside of the radiator and didn't cause a problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jerbob Quote  Post ReplyReply Direct Link To This Post Posted: 21 Oct 2017 at 4:00pm
I'm thinking just a good clean water flush at this point. Better than anything this old girls had in 40 years I bet.
