need help finding 5020 top bearing #
dt1050 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Topic: need help finding 5020 top bearing #
    Posted: 25 Apr 2017 at 9:42am
I was wondering if anybody has a different number for a top bearing for a Allis 5020 4x4, the agco number is 72098759. it goes in the top of the axle/final drive housing below were the tie rod bracket bolts to.
there wasn't a bearing at all on the right side, the left had some mangled pieces.  thanks dt.  even if somebody has the size/dimensions.  have a great day.dt
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2017 at 9:47am
I know where there is a 2WD front end if you get tired of messing with the 4WD stuff(LOL)
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2017 at 9:59am
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2017 at 12:06pm
Someone is parting out a 5020 in the classifieds here.
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2017 at 12:25pm
Try Western Kentucky Tractor Parts for it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 5:19am
no luck at western Kentucky.  wengers in Meyerstown pa searched and found 1 place that's selling them. around $70. + shipping each, and I need both of em. ugh.  payday next week.  looks like the parts for the d14 are gonna have to wait another month...I understand parts are hard to find for a 5020, but a bearing?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 5:24am
did you try the site I posted? $62 plus shipping
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 7:59am
Manufacturers number:
http://www.southern-global.com/4wd-top-bearing-set
Dimensions   SKF
http://www.skf.com/group/products/bearings-units-housings/ball-bearings/angular-contact-ball-bearings/double-row-angular-contact-ball-bearings/double-row/index.html?designation=3203%20A-2RS1TN9/MT33
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2017 at 12:12pm
I believe that's were they are ordering them from.  Thanks for all the responses.  glad tractor work is done for a little bit, bearings in the 5020 and the front grill radiator and such is tore off the d14 so I can make alternator brackets and install a hydraulic hub on the crank shaft pulley!!!  maybe I should by 3 tractors, so I can have 3 of em to fix at once....ConfusedConfused
Edited by dt1050 - 26 Apr 2017 at 12:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote dt1050 Quote  Post ReplyReply Direct Link To This Post Posted: 09 May 2017 at 3:57pm
the top bearings and seals are in and the tractor is back up and running.  I'm gonna be posting it for sale soon, so if there's any interest let me know. thanks dt
