Is this the hydro pump?
NATHAN CAIRNS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Topic: Is this the hydro pump?
    Posted: 18 Apr 2017 at 8:21pm
912 hydro.     I pushed down on the thing circled in blue and 2 pins sunk down into what i think is the pump.    Did i do something right?
B212, WD45, B, 912 Hydro
TOMIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TOMIA Quote  Post ReplyReply Direct Link To This Post Posted: 19 Apr 2017 at 4:10am
That is what you do to make the tractor free wheel so you can push it around. The hydro will not work with the pins in the down position.
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 21 Apr 2017 at 9:07am
The pins should pop right back up, as soon as the input to the pump spins.  The push handle above the pins is able to be locked down, to prevent them from doing so, and keep the tractor in the freewheel position when running.
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 6:00am
ok thank you   im glad i pushed those down now      :)
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 8:52am
Spray some oil on them so they don't stick
Edited by Mikez - 24 Apr 2017 at 8:52am
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2017 at 4:02pm
OK ill soak them in penetrating oil this weekend.
