AC 160 brake set lever
Badger Russ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Badger Russ Quote  Post ReplyReply Direct Link To This Post Topic: AC 160 brake set lever
    Posted: 11 Mar 2017 at 6:44pm
Regarding the brake lock lever. Anyone able to tell me where the rear of the spring attaches?? The front obviously hooks around the pin  that goes thru the clevis at the bottom of the rod. The parts manual shows a "leg" that the spring hooks to. I wonder if the leg was held on by the bolts that mount the platform assembly? Any help would be appreciated.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 7:06pm
boy, setting here at the computer, I can't tell you, but I'll try to take a look tomorrow. If I don't reply, get back to me, as it is old age etc. that may impede my response.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Badger Russ Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2017 at 7:09pm
I hear that :) I can remember some obscure detail from when I was five, but don't ask. me what I had for lunch today! thanks, and I will look forward to your response.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Badger Russ Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 2:38pm
Hi Dave did you get a chance to check the brake lever?
allisman55 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisman55 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 2:53pm
text me a number and I will send you a picture of mine, 715-760-1547
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2017 at 2:55pm
Yes, that leg (p/n 72073086) is secured by the lower bolt which mounts the foot board.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2017 at 3:14pm
Well, Russ, sorry for the delay, but got caught up in family matters and then photobucket wouldn't cooperate (anyone else have problems with it?). Anyway, if this works, there will be a couple pictures that should help explain connections.
