WD Single Piston, Rings, Sleeve |
MN-Realtor-Farmer
Topic: WD Single Piston, Rings, SleevePosted: 18 Feb 2017 at 12:22am |
My son and I finally got a chance to pull the motor out of the WD which had a stuck block today. We got three of the four pistons out without a problem. The 4th one gave us a little trouble but she finally relented. At the end of the day, I need a single piston, a ring or two, and a new sleeve to complete the repair. Most everything else is reusable. Does anybody know where a guy can buy single parts rather than an entire overhaul kit?
Edited by MN-Realtor-Farmer - 18 Feb 2017 at 12:23am |
Fred in Pa
Joined: 13 Sep 2009 Location: Hanover Pa. Points: 9210 |
Posted: 18 Feb 2017 at 6:11am |
Will need a bore size and piston # to start with .I can sell u 1 new Piston sleeve kit , will have rings and piston pin. But its going to be 4.125 bore. if u have a 4 inch bore ,u will be looking for used on piston and sleeve ,then u can get new 0-rings for sleeve and new rings for piston .
Adam Stratton
Posted: 19 Feb 2017 at 7:07am |
Depending on the condition of the other 3 you might wish you had either all 4 new or all 4 similar used. I have some used sleeves and pistons around and I'm sure some others do too. You would want to make sure measurements and styles matched regardless of which way you went
MN-Realtor-Farmer
Posted: 19 Feb 2017 at 2:53pm |
Casting number is 224753. Bore is 4".
Don(MO)
Joined: 12 Sep 2009 Location: Bates City MO. Points: 6862 |
Posted: 19 Feb 2017 at 3:24pm |
You WD has 6.6 to 1 comp pistons and the old AC part number for the piston is 224754
The AC Sleeve part Number is 207435. New AGCO part numbers are for the piston- 70224754 running on gasoline for high altitude and sleeve is 70257450. |
JimD
Joined: 11 Sep 2009 Location: Mounds, OK Points: 2116 |
Posted: 20 Feb 2017 at 9:05am |
I'll go dig and see if I have any in my assortment of pistons, doubtful on the sleeve. You will be happier in the end with a full kit though.
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8459 |
Posted: 20 Feb 2017 at 9:18am |
I know you can buy a new sleeve, piston, and ring set for a Ford N series, not sure about a WD though. I agree, you might as well do all 4! You already have it apart, so why not? It's not hard at all.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7574 |
Posted: 20 Feb 2017 at 10:10am |
If I had the engine completely torn apart, I would replace everything while I was in there. Then you would know for sure that everything will last for a long time.
MN-Realtor-Farmer
Posted: 20 Feb 2017 at 3:07pm |
I should probably clarify the purpose of this rebuild. My family and I recently moved to 10 acres and bought a WD45 to help around the property. The tractor came as a 2 for 1 deal with a WD that had a stuck block. My son and I have been having fun taking it apart and trying to get it back running again. If I can get it running again, my plan is to sell it and offset the cost of the WD45 which is what I really wanted in the first place.
I understand that when you tear them down this far, you should really repair and replace everything, but my hope is simply to get an education and get a tractor running to sell at some point. Sinking an extra $450 into the unit while worthwhile, will not bring and additional $450 from the sale and as such, it is a loss leader. My hope is to simply replace what I broke while taking it apart and put it back together as a runner for someone else.
Adam Stratton
Posted: 20 Feb 2017 at 6:28pm |
I know exactly what you mean. I bought a large stock of take out sleeves and pistons at a dealers close out auction last year. I will try to dig through my stock and see if I can match one for you.
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2043 |
Posted: 20 Feb 2017 at 6:32pm |
After you get it running, what price do you think it will sell for?
MN-Realtor-Farmer
Posted: 20 Feb 2017 at 7:08pm |
Lon, I was thinking around $1,000. Do you need another one for the collection?
IBWD MIke
Joined: 08 Apr 2012 Location: Newton Ia. Points: 4198 |
Posted: 21 Feb 2017 at 10:17am |
I have a set of 4" bore pistons, sleeves, and rods for a WD that are going to Booneville. Good used condition. Also have the crank, It's standard but needs ground.
