Which cabs fit a 170?
jon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon Quote  Post ReplyReply Direct Link To This Post Topic: Which cabs fit a 170?
    Posted: 03 Jun 2013 at 10:09am
Have been told by some that only a cab for the 170/175's will work on a 170.  Others say any cab for the 170's thru 190 will work.  Does anyone know for sure?  Thank you Jon
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2013 at 11:51am
170 or 175 are the same and a 180-185-190 sure will NOT fit.  Your tractor is a utility profile that sits very low and a cab will be difficult to find....not many of this model ever got a cab.
jon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jon Quote  Post ReplyReply Direct Link To This Post Posted: 03 Jun 2013 at 12:43pm
Thank you Doc,that is not the answer I wanted to hear, but it was what I thought.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2017 at 8:48pm
Will a 170 cab fit a series 1 D17?
Or what cab can you put on a D17?
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote allischalmerguy Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2017 at 8:54pm
Never mind, I found This post on the forum click here
Mike
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2017 at 9:12pm
Here is my 175 when I bought it, sold the cab to Bruce in NC, but you might be able to blow up the pic to see the brand.
I also bought a 175 with a cab from a 180 on it, so you can get them to fit, just takes some work. They cut up the fenders to fill in areas....and the seat had to be modified...but it worked for years for the previous owners. I took it off and sold it to a guy with a 180.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2017 at 9:17pm
180/185 cab
ALLIS EXPRESS!
This year:
ksbowman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ksbowman Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 8:36pm
I put a 180 cab on my 170. It does take quite a bit of work, but it works pretty good.
7060 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 7060 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2017 at 9:14pm
I have some year around cabs that you might be able to make work if your interested. I'm 50 miles from you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 11 Feb 2017 at 8:11pm
My neighbor bought a 170 new from my grandfather with a cab just like eldons picture. It's like a full vision or something
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 12 Feb 2017 at 2:14am
  our 185 had an ansel cab on it.    actually the only complaint is every once in awhile the 3pt would brake out the back window.  AC worked well and was actually quiet.   but then it was a new tractor with a new cab.
This page was generated in 0.052 seconds.
