D15 Series II Rear Weights |
BrianC,Ont
Joined: 11 Sep 2009 Location: Belleville Ont Points: 903 |
Topic: D15 Series II Rear WeightsPosted: 13 Jan 2017 at 10:34pm |
I just bought a late model D15 Series II with loader. I just realized tonight that the rear tires are loaded, but it doesn't sound like they are full. I was looking to put a wheel weight on it for loading logs this winter. The weights I have look like Allis, but there are no casting #s. I am guessing they are 150lbs each. Just looking for advice to see if it would be good to run the weights with the loaded tires.
Thanks Brian |
35WC on steel, B with belly mower, D17 puller, D15 Series II puller, D15 Series II with loader, 608 Lawn Tractor
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7579 |
Posted: 13 Jan 2017 at 10:48pm |
D15s used 4 section pie weights on the rear wheels. If I remember correctly, each section weighed 55 lbs. I sold them a few years back.
BrianC,Ont
Posted: 13 Jan 2017 at 11:00pm |
Hey D,This tractor came from up in your neck of the woods.I have a set of pie weights off of a D17.I held one up to the rim and it looks like 4 will fit on the rim. The wheel weights i have are for 28" rims, but they have the same 14" centres on the holes. They will bolt on but wont be right up against the rim. I will have to use longer bolts.
DSeries4
Posted: 13 Jan 2017 at 11:07pm |
D15 and D17 wheel centers are different - will not fit. D15 centers have a flat face, D17 centers are dished - the weight sections will not sit properly on it. The square holes are the only things that are the same.
Dan73
Joined: 04 Jun 2015 Location: United States Points: 6054 |
Posted: 14 Jan 2017 at 12:56pm |
As to weights and loaded tires yea you can do it. But how do you plan in using the d15 most of the time? I have a grapple that picks up 15 square bales on my d15 in the summer and a bucket I use when I am not haying. I have loaded tires and they are not enough for the grapple. Which is too heavy for the d15 really not for the loader but for the tractor. So when I hay I add a 3 point counter weight and go slow and easy on the tractor. Not a great idea but it does get the job done. I think the loaded tires alone on a d15 are plenty of weight if you go more then that I think it is really just allowing you to over load the tractor and the front end. That is how I feel driving mine and yes as I said I do do it but I only run the extra weight when I need to.
EPALLIS
Joined: 12 Sep 2009 Location: Illinois Points: 1166 |
Posted: 14 Jan 2017 at 9:42pm |
I have the WD rear wheel weights on my D-15 series II. I just had to repaint them from Persian orange #2 to the cream color and they worked just fine. Hope that helps.
Farrell(Utah)
Joined: 11 Sep 2009 Location: Springville, Ut Points: 558 |
Posted: 14 Jan 2017 at 10:45pm |
I used a set of CA rear weights on mine. Everything seemed to fit OK.
A(1937), 2 G, 2 WD45 diesels, 6 WD45 gas, UC, 2 WD, D17 gas, WF, Farmall 400, D12, Kubota B3030
BrianC,Ont
Posted: 15 Jan 2017 at 11:01am |
I will only be using it at the landing for loading logs. Will likely take the weights off after that. The loader has a front mount pump. It sure works better now that I put a 1/2" line from the pump to the valve instead of the 3/8 that was on there.
Dan73
Posted: 15 Jan 2017 at 12:02pm |
A counter weight would help more to ballance the logs and lift a little weight off the front end. Wheel weights will provide more traction but won't help with the front end weight and steering.
