B overhaul -include oil pump?
Tom Elder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Elder Quote  Post ReplyReply Direct Link To This Post Topic: B overhaul -include oil pump?
    Posted: 21 Dec 2016 at 9:31am
Before the disassembly,the pressure was probably at the o in normal,i am wondering what i need to do as far as oil pump goes.The rebuild kit is 120 dollars the vanes are 40.Seems like the old vanes if cleaned good ,would be a broke in fit,but i am a novice.Maybe new springs and gaskets,will i be sorry? Any one been there done that?
thanks to all Tom
2 1949bs,one with belly mower one with side sickle bar
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 11:26am
Do you have the pump apart? Any pumps that I have had that was low on pressure and the vanes and springs were good lost the pressure from an eat out cover or the ball in the stem was not holding.  Other  problems can exist like stem bushing being wore over sized.
The cover on the left looked like the one on the right before I resurfaced it.  The ball in the picture is rust pitted.
Edited by Dick L - 21 Dec 2016 at 11:27am
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 2:54pm
The unscientific method that I was told is if the pump will pump mineral spirits then it will pump oil just fine.
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Elder Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 3:46pm
Thanks men you  both helped, Mine is not scarred at all,so i am thinking springs  on vanes and relief valve ,maybe a ball also ,a cleaning and back together ,also looking at the end play
Bob-Maine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bob-Maine Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 4:06pm
Before I had a shop to do my own restorations, I had a friend/restorer do my '39 RC. About a year after it was done, the oil pressure went to zilch. I pulled it apart and the pump showed signs of tinkering - the screw slots were all buggered up, there was a lot of wear in the pump, broken spring, etc. I bought a new pump from Sandy Lake and all is fine (after new rod & main bearings and cam bushings). I certainly don't want anyone to think I put any blame on my friend as the project cost had gone so high I think he felt that I was in deep enough. But my point is, I won't button up another engine unless I am sure the oil pump will do it's job. Tom, I think you are on the right track. Bob@allisdowneast
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 6:03pm
The gasket under the cover does not want to be thicker than .007. I mic different sheets of paper and cut a gasket from the proper thickness if I do not have the proper gasket set.  If the gasket is to thick it will bypass oil the same as if the cover is bad.
Norm Meinert View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Norm Meinert Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2016 at 10:37pm
I rebuild the oil pumps by remachining the housing and putting in new parts needed. as stated above the end plate clearance needs to be set close, .001 to .003 clearance.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Elder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 5:28am
you guys are above and beyond,
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 6:23am
Make sure you check the pin in the camshaft that drives the pump while it is apart.
NORMAL in the gage with the needle on the O is still (normal) oil pressure which means your pump is/was not all that bad.   Your loss in the pump pressure if any could be in the filter area.
If an overhaul is/was needed it sure is time to check out the pump and make sure it is in top condition.
Edited by Dick L - 22 Dec 2016 at 6:35am
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 9:44am
Yep! Mine was worn pretty bad, If that pin breaks, you lose your oil pump action.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Elder Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2016 at 11:10am
thanks men,will do
This page was generated in 0.391 seconds.
