Shifter needs rebuilt 37 WC
psheridan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote psheridan Quote  Post ReplyReply Direct Link To This Post Topic: Shifter needs rebuilt 37 WC
    Posted: 13 Nov 2016 at 3:58pm
In the act of rebuilding my 37 WC
the shifter is really loose, I would like to tighten up the wobble in the gearbox
Is this a big project?
thanks
Paul
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Nov 2016 at 5:49pm
You will have to remove the shifter assy, disassemble the reverse lockout then remove the shift lever. Then you can check the groove in the shift lever and the pins in the tower and assess what all has worn- the holes in the tower, the pins, and the lever. Oversize pins are available, but if the groove in the shifter is worn you will have to have it filled and re-machined.
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
This page was generated in 0.106 seconds.
