30wt VS 15W40 oil pressure |
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8520 |
![]() ![]() ![]() ![]() ![]() Posted: 05 Nov 2016 at 11:01pm |
Is it likely that you have higher hot oil pressure with 15W40 over straight 30wt? 15W40 is supposed to act like 40wt hot so that would make sense.Just wondered. I put 15W40 in my 220 last winter and used it for all fall work this year.It runs just under 60psi WOT and I could swear it use to only make 50 with the 30wt but,it's been about 6 years since it really got worked and I got CRS.
The 8070 is out of commission for the time being,ergo using the 220. |
CrestonM ![]() Orange Level ![]() ![]() Joined: 08 Sep 2014 Location: Oklahoma Points: 8452 |
Uh oh...another oil pressure thread! Batten down the hatches!!
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21479 |
Not been my experience. 30 wt will carry a couple more pounds of hot oil pressure than 15W-40 does.
Lars(wi) ![]() Orange Level Access ![]() ![]() Joined: 14 Sep 2009 Location: Permian Basin Points: 7812 |
Years ago, I owned a delivery truck (IH 2155 w/ dt466) that did alot of slow idle with a pto, in the summer I ran 30w, in winter 15-40, it alway's showed higher pressure even in the hottest day's with the 30w that it did in the winter with 15-40.
Gary Burnett ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Virginia Points: 3024 |
I run 15W-40 diesel grade oil in every engine I own and when I change oil the first time in a tractor I buy the oil pressure almost always increases,of course i don't have any way to know what was running it when I bought the tractor.
ac45dave ![]() Orange Level Access ![]() ![]() Joined: 23 May 2015 Location: SE(IN) Points: 1343 |
![]() Edited by ac45dave - 06 Nov 2016 at 7:27am |
Dan73 ![]() Orange Level ![]() ![]() Joined: 04 Jun 2015 Location: United States Points: 6054 |
2x LMAO |
i always found in my own experiences, straight weight oil to carry a little higher pressure than multi weight oils.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 86125 |
the straight weight might have a slightly higher pressure than the 15w40. "Theoretically" they should be similar , but remember, the multiweight is a combination trying to solve multiple problems. The main advantage of a 10w30 or 15w40 is not the pressure when HOT, it is the advantage of thin oil when COLD to get the oil flowing quicker.
That would have been my guess too.Kinda why I ask.I guess I'm okay with what it is but am a little puzzeled. |
