Distributer Conversion, kit Per Trtronix ??? |
Macon Rounds ![]() Orange Level ![]() ![]() Joined: 18 Feb 2010 Location: Pittsburgh Pa Points: 2229 |
![]() ![]() ![]() ![]() ![]() Posted: 23 Sep 2016 at 5:51pm |
Anyone know the part number for PerTronix Conversion kit for 4cyl. Ford 2000 tractor ? This tractor has been converted to 12 volt, negative ground. Using alternator.
Ready for ignition upgrade. Thanks in advance Edited by Macon Rounds - 23 Sep 2016 at 5:52pm |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54137 |
most places that sell pertronix will have a list of the kit you need. You will need to know if it is + or - ground, and a 3 ohm resistance coil, I believe. Cheapest place I have found is the Brillman Co, virginia...
Dan73 ![]() Orange Level ![]() ![]() Joined: 04 Jun 2015 Location: United States Points: 6054 |
Steve at B & B custom circuits can set you right up. Or get the part number off the distributor and search for a kit to match that distributor. It should be a 12 volt negative ground tractor and you should have a 3 ohm coil without a resistor. The older ford 800 serries was 12 volt negative ground with a 3 ohm coil so I am pretty sure the 2000 is as well.
Thanks for the replys !!!!!
