check valve I-600 box blade |
bgabriel
Topic: check valve I-600 box bladePosted: 19 Sep 2016 at 3:53pm |
Does anyone know if the AC I-600 has a check valve on the hydraulics for the rear box blade? If so, might they have a photo or a location of where on the tractor it might be located? Any thoughts on where replacement seals could be obtained for this check valve?
Eric B
Joined: 09 Feb 2012 Location: British Columbi Points: 1012 |
Posted: 21 Sep 2016 at 4:55pm |
What makes you think it is specifically the check valve you need to address? If the hydraulics bleed down it can be the seals in the hydraulic cylinder that need replacing or a leaky hydraulic hose leaking internally. Just suggesting possibilities...
