Coolant through radiator question?
Bensjamming View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Topic: Coolant through radiator question?
    Posted: 19 Sep 2016 at 7:13pm
So having problems with my C overheating get slowly at a fast idle in the garage. I have drained the coolant and fillEd and drained with water 2 times and now have water and a bottle of peak flush in it. Still getting alot of craplaces out of it. Especially the small shiny specs of metal from bars leak....
I noticed though with the peacock open on the radiator I can pour a gallon of water in the top and it bubbles and gurgle then slowly comes out the bottom. Should it just ruse right through it? If it's plugged can i ret putting in sk.e water followed by a blast of air from the compressor to try and free the blockage? How much psi would you use?
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 7:23pm
Take it to a radiator shop and have them clean it out. From your description it's all gunked up.
Edited by DougS - 19 Sep 2016 at 7:24pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 7:38pm
x2
Tcmtech View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 7:55pm
 How ambitious do you you want to get on this yourself and how bad off is the radiator anyway?
Reason being I have done some pretty wild cleanouts on old radiators that I figured were near dead anyway that actually save them.
The simple one is to rig up some fittings so that you can attach both a garden hose and air hose to the lower return hose and just let it go nuts with a good heavy water and air flow.
A  good reverse flow with a high level of air agitation will knock most loose crust out but if your core is almost corroded through there is a fair chance any pinholes it had that are plugged by crust will open up.
The next wilder method I have done is to take the radiator out lay it on its face and fill it with a high concentration of muriatic acid and let it sit in the sun and cook for a hour or two  while sloshing it back and forth every 5  - 10 minutes to circulate the acid that is in the end tanks through the core passages.
Muriatic acid is just hydrochloric acid in a  ~20% mix and won't bother copper, brass or cast iron unless exposed for a long time at full concentration but it goes nuts with the mineral deposits that build up  in cooling systems.    (Blinding, lung burning, skin itching chlorine  vapors while it's eating the minerals.)
The downside is if you have pinholes held shut by that crust there is no turning back  once the acid gets going.
I've also done hot flushes of whole cooling systems that way as well. I run the engine up to  temp with clean water in the system then dump out aobut 1/3 - 1/2 then refill with acid and let it run for a while with that in it.
As long as there is only cast iron brass or copper in the cooling system it works pretty well but afterwards multiple forward and reverse flush outs and a few more a day or two later are needed because a lot of junk gets broken up and will keep peeling off the inside even once the acid is gone.
Also as with having pinholes in the radiator if you have any corroded soft plugs you're going to find that out too. Shocked
If you've never worked with acid I dont recomend it. But if you have and understand necessary safety precautions it's an interesting experience to behold.  Witches brew 101! Tongue
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:15pm
Somebody put the Bars Leak in there for a reason... Besides being plugged up, you probably have a leaking core... I agree with --- the shop clean it out and see if the core is any good and repair as needed.
Seems like most of the problem is the radiator, but you could have mud deposits around the cylinder liners also. Sometimes a little dish washer detergent will work as good or better than the radiator flush from the store.
LeonR2013 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 8:52pm
That's right Steve. Cleaned a truck rad. one time to get out the oil when cooler went bad. Thought I had flushed the soap out, but some was left in there. Ran it for a couple weeks not leaking and checked the water level. That rad. hadn't been so clean since new. If you use muriatic acid you need to do your final clean with baking soda and water. Be ready for a boil over as the soda kills the acid. I guess if you have some pin holes in the core you could always put in some stop leak and start all over again.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 9:05pm
Was told he put the bars leak in thinking it was a small leak in the head gasket and thought that would seal it up since he was having overheating issues too. That's after he tried a new water pump and thermostat.
As far as the acid, I have used mutation a few times for cleaning old sand points to tools to old rims to get ready for paint. It's some wicked stuff with nasty fumes but man does it work good. Just didn't know if that was too harsh for the system or not. Might have to try some dishwasher detergent if this stuff and flushing with with hose and air doesn't work. How much air pressure should I hit it with? My compressor kicks out at 150 psi. Also is this system supposed to be pressurized? The cap that's one tete fits very loose and doesn't seal it up very well but the fact that there's a brass overflow tube makes me think it doesn't matter really.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 9:06pm
Also there are spots that have been repaired on the radiator and didn't know if any of that stuff would eat the solder out leaving back at square one before it was repaired.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 19 Sep 2016 at 9:30pm
The old solders they used are lead based which has little issue with the acid.
As for the air you're using air volume not pressure so the more volume the better.
Regarding the dish soap for oil in the system.
A buddy of mine has a good sized salvage yard and one of their magnet cranes had an oil cooler leak into the cooling system so we did the clean water dish soap thing after we put the new intercooler in.
If a little is good more is better was the general mentality they came up with so two good sized jugs of dish soap went into a ~15 gallon system and the crane was ran hard for a few hours with the cap off.
No problem when running but when they shut it down the latent engine heat must have pushed the water and soap mix past it's flash boil point and it shot a gurgling stream of sudds a good 20 - 30 feet up for several minutes!  Confused
It also took flushing the system 2 - 3 times a day for nearly two weeks to get all the soap out.  Run for  2 - 3 hours then shut down and blow suds all over the scrap yard then fill and run again.  Big smile
I didn't think a bunch of growly old scrap men could laugh so hard! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 10:13am
OK so was doing a few crude tests to try and rule out what I can. This morning I started it up and let it run for about 5 minutes I was watching the coolant come out of the thermostat housing through the radiator cap hole. It seemed to have a somewhat decent flow right after starting while cold but after a few minutes of running once the temperature got around 120 degrees or so it almost looked like the floor started slowing down a little bit. Then I shut it off waited a few minutes and place my hand all over the radiator to see if there was any cool spots and warm spots. The radiator seems to be a uniform temperature all across the fence with only the very top and bottom part of the tank being warmer than the rest so that leads me to believe that the radiator must be flowing the coolant through it fast enough for the rate the water pump is pumping. Was told by the previous owner that he just put a new water pump on it before giving it to me and that did not solve the overheating problem. Next I plan to pull the thermostat housing off to see if in fact there is a thermostat in there or not because as soon as it started it was flooring coolant through the housing from the engine block. My other thought was with all the junk in the block from the bars leak being added maybe the thermostat is stuck partially open allowing it to pump coolant immediately upon starting but not fast enough fluid to maintain a cool temperature. I took a short video of the coolant flowing out of the thermostat housing into the radiator to see if anybody could take a look at it and see if they thought that was a normal flow rate the engine was running about half throttle during the video I would guess. I will upload the video and post a link to it as soon as it is done. And as always thank you in advance for any and all opinions or help as I am very new to the Tractor world but I'm excited to learn all I can.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 10:48am
Here is the video of it pumping. What do you think of the flow rate?
bigredisb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigredisb Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 11:21am
When I just did sleeves in my d15 I found tons of stuff packed behind #4 cylinder just do to the design of the water flow I guess. Not that it solves your overheating issue but you could have a bunch of stuff laying in behind #4 as well. On the D15 it has a block drain on the left hand side between #2 and #3. after I put mine together I wanted to flush out anything I couldn't get so I removed the shutoff valve and fished a RV water heater cleaning tip in the hole as it has a nice little 90 on it. It dislodged a bunch of trash as well. Just a FYI you may try that to get everything out so that your hard work in cleaning the radiator doesn't just get plugged up again.
1961 Allis-Chalmers D15
1949 Farmall Super A
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 11:21am
Just out of curiosity, have you confirmed your ignition timing is set correctly?
Reason I ask is my brother was using my backhoe the other day and it starting running real hot and had no power when loaded up yet sounded fairly normal when unloaded or idling.
Turned out the little fiber tab on the points arm broke off and retarded the timing about 30 degrees.
Also when overheating how hot are you talking?
Boiling over or the gauge says it's hot?
Edited by Tcmtech - 20 Sep 2016 at 11:26am
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 11:34am
I'm curious. You said you have good flow when the engine is cold, but little flow when the engine is warm. That seems bass-ackward to me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 12:22pm
Doug I thought the same thing. Gonna see what's up in the thermostat housing now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 12:23pm
The gauge gets to the red and I it down. Then you can hear it boiling in the radiator and block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 12:42pm
And yes put my timing light on it yesterday and the fire mark is centered in the hole with wide open throttle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 12:44pm
Well there is no thermostat in the housing at all. So makes me wonder if he got a used waterpump somewhere and it's just not working the way it should?
I tightened the belt to be sure it wasn't slipping and I can pour water right through the block so that's not plugged but I did get some chunks put of it. Going to flush it just to be sure.
My main suspects now are pump or radiator is restricting the flow as it seems it should be pumping more then it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 1:22pm
Is there much heat coming out of the radiator when it's overheating?
The fan should be blowing blowing plenty hot if it has enough circulation to see the water moving with the cap off.
All things point to either weak water flow or having so much corrosion the radiator can't transfer heat anymore. But then if you have loads hot air coming off the radiator that would change things again.
Edited by Tcmtech - 20 Sep 2016 at 1:23pm
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 1:38pm
No thermostat can cause overheating. Been discussed on the forum several times. When I worked at a dealship a C came in with an overheating issues. The old mechanic there asked me what I thought it could be and I gave him my opinion then he told me he'd bet the was no thermostat in it. He was right and a new thermostat fixed the overheating issue.
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote LeonR2013 Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 2:58pm
When you do your final flush, use non foaming dry soap. Probably can get it at Wally World.This will allow you to get rid of the soap so much easier. Really, it won't take a lot of time or water either. I always leave all petcocks open and adjust the hose to keep  it full, and run it until clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 4:48pm
I'll have to try that. It's just called non foaming dry soap?
About the thermostat..... about 3 years ago he gave me some boxes of bolts and various hardware he cleaned from his shop when moving and in one of the them was a new allis chalmers thermostat still in the box. Well needless to say I moved it around up until we moved in June and am pretty sure I tossed it out thinking when will I ever have a mid forties AC tractor. Lol this exactly why I tell my famoly I hold onto stuff cause you never know when your gonna need it. Guess I'll have to order one up with the gasket set....
Also another question I have is what to look for on a bad water pump? If the impeller looks good, bearing feel smooth and tight and no cracks could I consider it in good repair or is there other factors I'm not thinking about?
Finally if anyone would care to take a little picture of the amount of flow coming from their water pump through the cap to compare it would be appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2016 at 5:04pm
No thermostat is not the problem. My CA ran without one for 15+ years. I only used the shutters to maintain temp. The rad also had 5 or 6 tubes blocked off due to damage.
If you're going to clean out a cooling system with some type of soap, Cascade dishwasher detergent works much better that anything that foams. It's more aggressive too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 7:32am
I can attest to what Big Red mentioned about the muck that was packed in around the sleeves. When I did the engine in my B, after I got the sleeves out, I couldn't believe how much muck was packed around those cylinder sleeves! With a putty knife, I dug out muck to make a pretty large pile in a spackle bucket! I didn't know if that engine ran hot before I purchased the Tractor cause it didn't run for a long time and sitting outside with a rotted off muffler had all the cylinders filled with water. I also had my Radiator man rod out the Radiator, and that was full of muck also. I know the little AC Tractors don't normally run hot unless there is a problem somewhere in the cooling system. My little B can run in the hottest of weather and never get into the Green area on the temp gauge. Even if I roll the shutters closed, it only goes up a tick...
Steve@B&B
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 8:04am
It may be that the block is packed with crud as mentioned.  I seen this problem on a 45 block.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bensjamming Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 1:27pm
Once the sleeves are removed can they be just reinserted or is there any orings or seals that's need to be replaced? Going to be doing a head gasket and was hoping I'd be able to just poke around in the holes there to loosen up anything in there.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 2:20pm
I thing you might try first is fill cooling system up full and them drain and count the quarts of coolant you removed and check that number to the number of quarts the tractor calls for if you removed less that it called for you have crap left inside and then open the engine up and remove the sleeves and clean the block, head and radiator out.
cdon_FL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cdon_FL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 2:31pm
back in the day....lots of guys with warmed-over flathead Ford engines removed the thermostats to try to increase coolant flow and prevent boilovers. But doing so turned out to be counterproductive. The coolant water turned over TOO fast -- did not have enough time in the block to gather up the latent heat or enough time in the radiator to shed it.
Chris in NE Florida
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tcmtech Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 2:37pm
Given it has ports for coolant to flow between the block and  head once you have head off for the head gasket job  you should be ble shoot a stream of water down those holes and get most of what's at the bottom of the coolant passages knocked loose.
Got a pressure washer or know someone who does?  A jet tip should blast that stuff to bits without needing to pull positions and sleeves.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2016 at 2:45pm
Tearing the engine apart seems to be a bit extreme until you've had the radiator cleaned and checked out. IMO
