Just bought my first B10
DanielGagnon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielGagnon Quote  Post ReplyReply Direct Link To This Post Topic: Just bought my first B10
    Posted: 20 Aug 2016 at 4:09pm
Hi,
I hope you are all well.  I have a fairly basic question.  I bought a B10 that apparently was running 15yrs ago before indoor storage.  After putting a new battery, plug, gas and oil, it spin well but there is no fire.  I know I should go check the points but before doing so, is there a kill switch that I should know about?
Here is a picture of the beast.
Thanks
Edited by DanielGagnon - 20 Aug 2016 at 4:11pm
ACmowerguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACmowerguy Quote  Post ReplyReply Direct Link To This Post Posted: 20 Aug 2016 at 9:52pm
Welcome aboard! The keyswitch is your killswitch. There are no safety switches on this tractor.
Edited by ACmowerguy - 20 Aug 2016 at 9:52pm
AaronSEIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2016 at 6:49am
Those engines are notorious for being mouse condos. If it sat for any length of time its possible mice have gotten under the blower housing and chewed through the plug wire.
AaronSEIA
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 21 Aug 2016 at 9:45am
great work horse, would not trade my 101
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2016 at 6:40am
A little spritz of TV tuner cleaner or Brakekleen on the points, and the ole' girl will probably fire right up! Aaron is right about those darn varmits. They get into everything, especially small engine flywheel housings! Probably wouldn't be a bad idea to pull the engine and remove the housing to make sure there isn't any varmit condo's in there. Could make a mess if there is. Welcome aboard! BTW, nice machine!
Steve@B&B
Edited by Steve in NJ - 22 Aug 2016 at 11:53am
Post Options Post Options   Thanks (0) Thanks(0)   Quote AaronSEIA Quote  Post ReplyReply Direct Link To This Post Posted: 22 Aug 2016 at 8:37am
If you pull the engine, I have a tip for the removal of the drive shaft bolts. Use a long pry bar or screw driver to hold the drive shaft from turning and break both bolts loose that are bolted to the flywheel. Then run them out. Hang onto the spacers, they can be a booger to find if you drop them. Also a good time to check the starter/generator belt. Driveshaft has to come off to change it anyway.
AaronSEIA
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielGagnon Quote  Post ReplyReply Direct Link To This Post Posted: 23 Aug 2016 at 10:37am
Thank you for the welcome and the great information. Everything is very appreciated.
I will make sure to keep this page posted.
In the meantime, here is my dash.  Some people think there might have been a hour meter at one point.  Also some more pictures.  Sad for the hood that someone changed the gas tank and made a second hole!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2016 at 7:04am
You can pick up a lot of parts on e-bay. There's a nice hood on there right now pretty darn reasonable in my opinion. I just bought a nice clean deck and fenders pretty reasonable for my Big 10. The same guy I bought the deck and fenders from is selling the hood. Ya just gotta' look around if you want to restore it correctly. I believe the same guy has the fuel tank also. He's parting out a Big 10...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanielGagnon Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2016 at 9:16am
I had a little time to look at the tractor and noticed that the metal box for the points had no seal.  After looking closely, the condensor's top rubber is crack and points are a bit rusty.  I think the spark issue might be in the points. I will try finding a replacement.
I would be happy if this works because removing the engine to access the magneto wires seems to be quite a job!
talntedmrgreen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote talntedmrgreen Quote  Post ReplyReply Direct Link To This Post Posted: 31 Aug 2016 at 6:11am
Before buying any parts use a piece of very fine sandpaper or Emery cloth and draw it between the points when they are lightly closed a time or 3. Every set of points I've ever failed to get spark from was remedied in this way. I don't think I've ever bought points and condenser for an old Briggs and wound up using them.
Patterson B1*B1/B1Forklift*B10*BigTen/B1Loader*B110*B208*B206*616*Homelite T16H/T8/T7/RM7E*Landlord/Loader/Trencher*Broadmoor717*Serf525*2110*7790*Legacy XL*Twin 20*Squire9*Squire6*JCPenny 494
