adapting wheels for your puller
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Topic: adapting wheels for your puller
    Posted: 09 Jun 2016 at 1:20pm
I am creating this post to document my process of adapting wheels to my tractor.  Some people use adapters, I chose to weld in a new center because its lighter and I like the looks better.  Right or wrong, I am commited now.
Here is a picture of the wheels and tires as advertised.  I decided on 16.9x34 because they offer the largest foot print in the classes i will be pulling in and should work well with my gearing and rpm.  and of course the old hard and sharp tread.
The 9 bolt pattern wont work on my tractor and the centers are set too deep so a cutting we go.
Here is the first step with the tires removed and the center out.  boy were those tires on there!!
With the center out i can cut out the 9 holes and insert my custom 6 hole center disk.  I had 6 hole center made by my machinist friend and the 9 holes removed at a machine shop so it would be centered and clean.  friends machine didnt  have a big enough throat/ swing
Center disk  tacked in.
Checking trueness?  and depth of rim on tractor.  UC's have a reputation for being very wide so im going as narrow as possible.  about two inches clearence between tire and brake housing.  I have measured the width at the wheels with tires fully mounted at 92 inches.  my brothers wc is 89 inches so not to shabby i thought.
Before the wheel center goes back on the rim i have to repair the holes cut where the center was removed.
Since I was cleaning the final drive up and installing new seals, i laid it over and mounted the center then installed the rim to final depth and spun it checking to see how true it was before i made it solid.  apparently i didnt get a pic mounted.
In my haste to get them done, i didnt snap a picture of welding the centers to the rim.
Picture after sandblasting and painting black.
Pictures on the tractor to come very soon i hope.  I have the rims on and tires mounted but would like to get tractor outside for a good picture.   Will share more tractor details then.Big smile
ok i found this picture i had of the tires and rims mounted but im a little embarrassed by all the junk laying around lol.  still a work in progress.  all the bolts and alignment dowel are not it, i still had to pull the left final at this time.
Edited by CAL(KS) - 09 Jun 2016 at 1:57pm
mjbower View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mjbower Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jun 2016 at 7:03am
Yes please keep pictures coming always wanted to Build a UC to pull
Amos View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Amos Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 7:41pm
Good work!
dawntreader74 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Jul 2016 at 9:36pm
i would keep a eye on them for cracks' you did a nice job' but welding on them takes the temper out of the rims ' some times it will bust out next to the weld.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 7:55am
will do.  Hope to make inaugural pull this weekend. I will post some pics
Post Options Post Options   Thanks (0) Thanks(0)   Quote dawntreader74 Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jul 2016 at 11:23pm
good luck at the pull''
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 6:04pm
What junk? It all looks like a functional shop!
180Puller View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 180Puller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Jul 2016 at 10:28pm
Looks good...Cant wait to see the UC on the track...Its been a long time since I've seen one pull...Did you know the late Wayne Whitely at Abilene?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jul 2016 at 8:08am
I am not familiar with that name but my family only moved to the area in '92 and Abilene is our town rival so I never really associated with them much.  LOL  I have the iron for wheelie bars and front bracket, friend and I are going to throw them together tonight.   going to wait on the hitch as im still looking at examples and very short on time..... nothing like last minute
This page was generated in 0.081 seconds.
