190xt exhaust sound
Hitman79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hitman79 Quote  Post ReplyReply Direct Link To This Post Topic: 190xt exhaust sound
    Posted: 29 May 2016 at 1:12am
At this point it has the stock 3 inch straight pipe. How do you get that deep tone bigger pipe? Does a longer pipe sound different? Tell me what you know about the diameter and length of pipe vs. sound. Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 4:56am
Had a 5 inch on a 200 for a while, it gave it that deep throaty sound , it was 3 ft long, id rather have the 3 in, it has the sizzle sound
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 5:58am
you could always buy an old church organ, and make beautiful music, while plowing, or spreading shCensoredt...
[TUBE]http://youtu.be/HqK4PvbtBvE[/TUBE]
Edited by DiyDave - 29 May 2016 at 6:01am
screwloose View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 6:45am
I have a 4 inch straight pipe on mine, I think it's 3 ft 6 inches long. Any shorter and the exhaust would be coming back into my eyes and burning them. It sounds throaty. A 5 inch might have a deeper sound, don't know how much.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hitman79 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 6:47am
Do you still get the turbo whistle with the larger diameter pipe. More whistle or less the bigger you go? Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote screwloose Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 7:13am
I never heard a whistle on mine, I think the whistle comes from air sucking in the air cleaner not the exhaust. I might be wrong, I don't know. Either way I think the straight pipe will cancel out/overwhelm/out do any whistle.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 7:33am
Less on bigger pipe, you get a whistle at idle, and up to mid rpm,s but then it kinda gets drown out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hitman79 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 9:44pm
How do you guys get a 5 inch through hood? Don't want to cut my hood maybe 4 inch will fit but I'm sure 5 inch would require cutting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 10:24pm
I don't think a 4" will fit through the hood without cutting.  I am going to keep my 3" pipe and just fit a 4" pipe over top of it after it exits the hood.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hitman79 Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 10:55pm
I hear ya. I just think it's a cleaner look if I could get the 4 inch through the hood. Then you don't get that bubble look on top of the hood.
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 29 May 2016 at 11:46pm
If the hole is big enough for the newer 200 style muffler then 5 inch will go through the hood. I made a pipe start with 3 in then use a plasma cutter or whatever you  have make a donut that goes 3 to 5 then welded a 5 in to it. you could make the 3 in long enough and start the 5 outside the hood. You got the 190 with the 20.8x38s this spring would like to see some pictures of that one?
Edited by DanWi - 29 May 2016 at 11:48pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hitman79 Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 12:42am
Send me your number I'll text you some pictures. Not real good with the download or upload stuff. It's a work in progress everything seems to work good. Only bad thing is they cut the fenders some to fit thoes big tires.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2016 at 6:38am
5 inch works on a 200 hood and sounds awesome at 48 inch length. 4 inch works on a 190XT hood.
