616/620/720 cooler line
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Topic: 616/620/720 cooler line
    Posted: 09 May 2016 at 9:35am
what kind of hose are you guys using?  Also what ID and if you know how much I need.
Thanks
David
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 7:50am
anybody?
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 10:35am
i used napa # atp 14864 1/2 " transmission oil cooler hose 300psi
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 10:37am
Hud you don't remember how much you needed do you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 12 May 2016 at 10:51pm
no but it s only a about 2.50 a foot i think four foot piece will do it
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2016 at 7:17am
gotcha, i've noticed after mowing the first time since putting the engine back in that there was a drip on the center pulley of the mower deck so I assumed i have a line that either crack or slipped off the cooler.  I went to start the mower and raise the deck and had no hydraulics.  Turns out that in addition to the front leak somewhere the suction line that feeds the hydraulic filter had come off at the filter housing.  Don't know how that happened as I had mowed 3.5hrs parked it fine and then suddenly it was off.  Guess I should replace that one too and it doesn't like it will be much fun to play with the lower connection.
This page was generated in 0.242 seconds.
