Ford Guys...Remote Start
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Topic: Ford Guys...Remote Start
    Posted: 10 Mar 2025 at 4:15pm
Hi Guys,
  I've got a 2015 F150 and the remote start just quit working.  I started it at home and it worked.  Went to visit my sister and when I was going to leave it wouldn''t work.  I pushed the buttons and the lights blinked and the horn sounded.
What should I be looking at to fix it?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 4:27pm
Here is the sequence of event in order.. Sometimes if i delay too long between the "push this button, then that button" , or 2019 FLEX does not start......the HORN is not part of the sequence.. Horn is a signal that means NO START..
To remotely start your 2015 F-150, press the lock button on your key fob, then press the remote start button (the button with the 2x icon) twice within 3 seconds
The vehicle will start, and the exterior lamps will flash twice.
Here's a more detailed explanation:
  • Press the Lock Button: First, press the lock button on your key fob to lock all the doors.
  • Press the Remote Start Button Twice: Immediately after locking the doors, press the remote start button (the one with the 2x icon and a rotating arrow) twice, within a 3-second timeframe.
  • Visual Confirmation: You should see the exterior lamps flash twice, indicating that the remote start command has been received and the vehicle is starting.
  • Horn Indication: If the system fails to start, the horn will sound unless Quiet Start is enabled.
  • Vehicle Operation: The vehicle will run for a pre-set time (5, 10, or 15 minutes, depending on the setting).
Edited by steve(ill) - 10 Mar 2025 at 4:29pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 4:28pm
Check one of the 3 fuse panels for a blown fuse. Hopefully you HAVE the pristine manual in the 'glove' box. They should show where the fuses are and what they power. Hopefullly one is labelled 'remote start'.
Since the horn beeps,lights flash  is the signal to the 'starter system' that isn't making the trip. The 'control box' should be OK.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 4:31pm
also try standing 20 ft from the truck instead of in the house.. see if that works...
sparky View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote sparky Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 4:49pm
Maybe check the battery in the key fob too.
Steve in MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in MI Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 5:24pm
if you have a check engine light on the remote start won't work , at least on my dodge it wont
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2025 at 8:08pm
   Remember - Ted said it was a 2015 F-150
Teds Truck has probably heard all the Tariff News going around.
It realizes that when Canada stops shipping that 50% of Canadian
    Manufactured Truck Parts and that 100% of rolls of Aluminum to Stamp
   out all that Ford Pick-up Sheet Metal, Ford Manufacturing Trucks will cease.
Those few remaining F-150's, one's like Ted's, will become Collector Classics.
             AND MORE SOONER THAN LATER
       How does that Classic Song go?   Oh Ya   "LEAN ON ME"
    G
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 4:51am
    G
You forgot check the antifreeze, gaREE!  Politics belongs downstairs, and your hatred is showing again...Wink
And did I hear a request?LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 5:12am
Can attest to this one.  2017 Exploder, fob would Unlock doors or Lock them, would NOT open rear hatch or start car, was battery getting weak.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 8:29am
2015 is 10 years old........... battery change is a GOOD idea, even if not the problem.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2025 at 9:43am
Ya I guess you're right Dave, but it just seemed so fitting! LOL
   Funny nobody asked Ted if he still had the 2nd Remote that he could give it a try.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 6:10am
Well guys, I got er fixed!!
The batteries in the fob were good and as per Gary, I tried the 2nd fob and that too was no go.  So,,,,,,,,,,checking the fuses etal,,,,,,,,, I figured that if the lights flashed and the horn honked, that it wasn't the batteries in the fob or the 12v.
Did some checking on Youtube and there was some stuff about the pressure switch under the hood.  I went to look for that and there wasn't one!!  BUT,,,,,,slamming the hood shut,,,,it WORKED!!
Ergo, there has to be a switch there somewhere, but I couldn't find one.  At least there is nothing visible....
So,,,,,,,,THANKS guys!!  That did it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 6:12am
Also inspect for Rodent Damage to electrical cables, Eng Coolant Temp Ga loss on my SD Ford was a Rat Bite/Chew mark.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 8:33am
switch may be under the hood LATCH at the front.. Look for a harness with a couple wires... You should get an LIGHT/ ALARM if it was not working........... but glad it is fixed !
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 9:24am
Steve
If Ted hadn't got the Remote Start working, is that something that your
   recommended MotoPower OBDII Diagnostics Tool would give a code?
   I've never used an OBD Diag. Tool before.
   G
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 7:15pm
Question for Steve.
G
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 7:31pm
dont need a code reader.. should get an idiot light on the dash if the hood is open or switch not working.. just like leaving the door open , or tail gate, or check engine light..
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 7:32pm
@TED J
please do a test.
open hood and try to remote start the truck. see if it does or doesn't start.
curious am I .
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2025 at 7:39pm
If the light did not come on... then possibly something else prior to SLAMMING the hood... Yes, leave the hood open and try the remote start.. Also see that you get a LIGHT when you turn the key ON..
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 14 hours 49 minutes ago at 12:44am
There was no light on the gauges at all.  I tried just pushing the start button without the brake being pressed, and no lights.  Started and no lights.  Opened the hood and it wouldn't start.  I shut it like I always did and it wouldn't start.  Kind of slammed it shut and it works.  It was dark out, so I'll look later in the light to see if I can find the switch.
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 12 hours 19 minutes ago at 3:14am
Ford is a little freakish as they like to put switches at the latches as well as contact points.
D19allisowner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D19allisowner Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 8 minutes ago at 2:25pm
Some of the GM crap likes to put the switches in the latches so you have to replace the whole thing.
If you choose not to decide you still have made a choice.
