Factory front pump for 400 loaders |
Alex09(WI) ![]() Orange Level ![]() ![]() Joined: 15 Mar 2012 Location: CECIL WI Points: 1719 |
![]() ![]() ![]() ![]() ![]() Posted: 09 Jun 2020 at 9:09pm |
How many gallons per minute, or how much cubic inch displacement did the original front pumps have when sold with a 415 or 417 series loader? I think front pump for 519 loader may have been different.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21241 |
I don't think there's a difference in the loader front pump GPM's on a D-19/500 ldr. There was a D-19 auxiliary front pump to add to the 4.5 GPM belly pump flow and it would have been different and smaller than the loader pump.
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
I don't think they had front pump for the D19 like the D17. The pump like the D17 would be difficult to fit on a D19. The front axle support extends about 4 inches further out under the steering box and interferes with where the pump would mount. I have seen it done but it usually means chopping a big hole in the grill shell. It could be done with a longer shaft and mount spacers allowing the pump to be in front of the grill
Like Dr. Allis said, they had a smaller auxiliary pump using a flex shaft that mounted between the grill shell and the steering box. I have the pump, mount and diverter valve, but do not have the drive shaft or lines.
